Pages: [1] 2 3  All
  Print
Author Topic: 1000hp 2jz-gte Camaro  (Read 762 times)
sirdan
Hero Member
Rep: 8
Offline Offline
Lawn Guyland
View Profile WWW
« on: February 14, 2009, 09:05:56 pm »
this car is in this months hot rod magazine thumbs
http://videos.streetfire.net/video/EVS-Mot...4a-9af000e9e642
Logged
Modifications:
Cone airfilter
Supra AFM
Engnbldr 268c/Torker camshaft
Pacesetter header
F code rear end with disc brakes and 3.90 gears
Custom 1 piece drive shaft
PST polyurethane bushings in the rear end components
Addco Swaybars 1" front 3/4" rear.
zjr360
Newbie
Rep: 0
Offline Offline
View Profile WWW
« Reply #1 on: February 14, 2009, 09:27:42 pm »
Thats sooo badass! I liked the mustang with the nissan motor in it in Fas and furious: tokyo drift... But this is SO much cooler! A classic chevy with a badass 'yota motor!  thumbs
Logged
Go check out my Celica!!!
-ZJR
wadadlianu
Hero Member
Rep: 0
Offline Offline
View Profile
« Reply #2 on: February 14, 2009, 09:35:56 pm »
Nice idea, but sacrilege to me.  That must piss off alot of diehard bow tie guys.  Honestly I would have preferred to just turbo a GM engine and do that.  Now if only I could get my hands on GM's best engine - the 302. Sadly an engine very few knew about.
Logged
sirdan
Hero Member
Rep: 8
Offline Offline
Lawn Guyland
View Profile WWW
« Reply #3 on: February 14, 2009, 10:15:18 pm »
heres another video of it
http://videos.streetfire.net/video/67-Cama...=9&v=5c1dc94c02
i love his exhaust tips they make that car look cool.
isent the 302 and olds motor? is that the one they also boosted in the 80-81 turbo trans am?
Logged
Modifications:
Cone airfilter
Supra AFM
Pacesetter header
83GTCoupe
Gold Member
Hero Member
Rep: 3
Offline Offline
View Profile
« Reply #4 on: February 15, 2009, 01:01:50 am »
isent Isn't the 302 and Olds motor?
blink Bite yer tongue!! 302 is FORD. GM never made a 302. tisk
« Last Edit: February 15, 2009, 01:02:10 am by 83GTCoupe » Logged
"There are only three types of people: Those who MAKE it happen, Those who WATCH it happen, and Those who wonder... "What just happened?"
83 CELICA PICS 82 CELICA PICS
Supporter of TimmyRigTech Snooch to the nooch!
22-RZE powered 83 GT Coupe. R.I.P.:
Body had Swiss Cheese Disease. Snoogins
Supercharger installed. Car Fast..er!
sirdan
Hero Member
Rep: 8
Offline Offline
Lawn Guyland
View Profile WWW
« Reply #5 on: February 15, 2009, 01:31:05 am »
after some reasearch ive found:
302
Chevrolet produced a special 302 cu in (4.9 L) engine for Trans Am racing from 1967-1969. It was the product of placing the 3-inch stroke crankshaft into a 4-inch bore block. Although the 283 also used a 3-inch stroke crankshaft, it was a low performance cast iron crankshaft. The crankshaft for the 302 was specially built of forged steel. This engine was used only in the first-generation Camaro Z28. Conservatively rated at 290 hp (216 kW), actual output was around 375 hp (280 kW). This block is one of 3 displacements that underwent a transformation for the 1968/1969 period when the main bearing size was increased from 2.30 in to 2.45 in.
and also the turbo trans am was the 301.
never say never
Logged
Modifications:
Cone airfilter
Supra AFM
Pacesetter header
a2ndopinion
Hero Member
Rep: 17
Offline Offline
Pdx - Beaverton, OR
View Profile WWW
« Reply #6 on: February 15, 2009, 01:51:05 am »
Very few knew about? Maybe in your neck of the woods, and for the following, but not where I came from!
What!!!!Huh?? Matt, where have you been?
302's were available in '67-'69 Camaros.
Have none of you heard of a DZ302 Camaro?
The 302 is a 327 block with a 283 crank. That gave it a 4" bore with a 3" stroke (the 327 used a 3.25" stroke). It can be done with stock parts as there is nothing funny with deck heights and piston pin height (unlike a 327/350 comparison).
Probably the most famous of these engine is the 69 DZ suffix engine. This particular suffix had the highest production number of all the years.
In 67 the RPO suffix codes were MO and MP
In 68 the RPO suffix code was MO (MP was dropped)
In 69 it was the infamous DZ
All were backed by 4-spd transmissions and topped with a single Holley.
sirdan, good research, but not quite 100% correct. As far as I've found and have heard over the years, ALL 327s through '67 had forged steel cranks (I know mine does). In 1968, Chevy changed the main journal size, so the first 350s, in the '67 Camaro (only) had small journals, but in '68, when the 350 was available in everything, they had large journals. The '68 and '69 327s were the only 327s that had big journals. All of the small blocks up through the 350 used a 5.7" rod, but the 400 had a 6.0" rod. The 400 also used even bigger journals, the crank was externally balanced, and the center cylinders were "siamesed" - meaning the water jacket did not go all the way around the cylinders. It also had three freeze plugs on the sides, where as all others had only two. Chevrolet made the small block in 10 (yes, ten) different cubic inches in their 45 year run - 262, 265, 267, 283, 302, 305, 307, 327, 350, and 400. These were in various bores and strokes, for various different reasons - smog, torque, high RPMs...
I could go on and on and on and on... but since this is not a Chevy forum, I will close my mental encyclopedia.
Yes, I am a Chevy fanatic too (got the bow tie tattoo to prove it)!
« Last Edit: February 15, 2009, 02:19:48 am by a2ndopinion » Logged
ASE certified Master Auto Tech, Master Truck Tech, Master Machinist, and Master Collision Repair/Refinishing Technician,
Parts Specialist, Service Advisor, Undercar Specialist and Collision Damage Estimator, State of Oregon certified Vehicle Appraiser
Celica 20/22R/RE fanatic, 4 2nd gens, 2 3rd gen GT-Ss ('vert & liftback), '81 22R Corona wagon & more!
Hybrid motors, Cannons w/ Side drafts & 32/36s, Offy w/ 4bbl Holley, stage 1, 2 & 3 cams... Chevy lover too!
83GTCoupe
Gold Member
Hero Member
Rep: 3
Offline Offline
View Profile
« Reply #7 on: February 15, 2009, 02:22:58 am »
I stand corrected. I've never heard of a GM 302 in my life Bob. Also, the 327 was very common on the Camaro's back then, as was the 250 straight six. Both must have been much more prevalent.
« Last Edit: February 15, 2009, 02:30:18 am by 83GTCoupe » Logged
Sigma Projects
Hero Member
Rep: 6
Offline Offline
View Profile WWW
« Reply #8 on: February 15, 2009, 03:28:40 am »
I only know about the 302 because I heard the reason they had it was for racing reasons and they stop using the 302 because rules changed and allowed for a 350 and GM changed to it.
I also know that GM used to make a newer 5.0L since in my dad's 98 Express it had one, didn't really like it much and much preferred the power the 5.7L had. The 5.0 was a Vortec motor. Then the 5.3Ls came out and not too long ago the 4.8Ls.
edit: sweet motor, wish they went with the Vortec 4200 instead and keep it GM  Sad
« Last Edit: February 15, 2009, 04:07:48 am by Sigma Projects » Logged
1984 Celica GT Coupe    sold and missed it
1983 Celica GT Coupe    attacked... will miss it (RIP) JY
1982 Celica GT Liftback  sold and won't miss it, lol
1985 Celica GT Coupe    new love =P
wadadlianu
Hero Member
Rep: 0
Offline Offline
View Profile
« Reply #9 on: February 15, 2009, 10:04:44 am »
Matt you disappointed me.  There was I thinking you were the GM man to consult.  The 302 to me is the best GM engine ever built, possibly the best push rod engine ever built. 8000 rpm redline on a push rod engine.  I would pimp you out to Elton John just so I could hear that engine rev.
Next thing you will tell me Ford never had a 427.  It s strange that the big 3 had these wicked engines in the early 70s and now are trying to play catch up with the rest of the world.
The Ford Cammer engine was said to produce way over 500hp in the 70s.  Most reported it was actually over 700hp, but Ford reported just around 500.  The GM 302 we know was way more than 450
Logged
celica fanatic
Hero Member
Rep: -261
Offline Offline
Post whorimus maximus
View Profile WWW
« Reply #10 on: February 15, 2009, 11:47:10 am »
Everything I know is officially a lie as of today. blink
Logged
Build a man a fire, keep him warm for a day. Set him on fire, and keep him warm for the rest of his life.
"nightmare"
1982 Supra L-type
7m swapped!
トヨタ
Quote from: uncleremuslegend
dude don't be gay...wait, you can't help it...
celica83_gts
Hero Member
Rep: 0
Offline Offline
View Profile
« Reply #11 on: February 15, 2009, 12:34:33 pm »
Wow, I must be old...I can't believe that people don't know of the Z-28 302! Built for Trans-am racing with a 305ci displacement limit, GM just put some off-the-shelf parts together and went racin'.
Wadi, you can easily do the same with some JY parts. As Bob said, 327 block, 283 crank. Watch the journal sizes, they changed sometime in the 60's. I'd go to a country wreckers for old parts like these, urban guys don't keep old stuff. Might take a little hunting, but it can be done. Put a good set of aftermarket heads on it, and it'll haul ass.
Logged
'83 Celica GTS, 22RTE swap, Garrett GT28R, Supra rear suspension swap w/ 3.73 LSD, Megasquirt EFI
13.940 1/4 mile
SOLD
'90 2WD pickup,  Rat-rod stylin'
'86 Pontiac Grand Prix, 6.0 LS, TH350
a2ndopinion
Hero Member
Rep: 17
Offline Offline
Pdx - Beaverton, OR
View Profile WWW
« Reply #12 on: February 15, 2009, 12:51:37 pm »
Yes, it was a rule change that stopped production of the 302. That also hurt Chevy's winning ways in the Trans-Am series, as Mopar had been hurt by the 5.0L limit, with the closest they had being the 273. Ford built the 302 Boss, which was basically Cleveland heads on a 302 Windsor block, but wouldn't produce squat for power down low. AMC used their 290 that was bored to 304. In 1970, the rule of a 5.0L limit was eliminated, and AMC became the top dog with their AMX and a 390.
Chevy's (GM) "new" 5.0L (305) used a long stroke with a small bore. So small in fact that you are limited on head use (1.72 intakes) because the 1.94 and 2.02 intake valves hit the cyl walls! It was introduced in '76, and was a "smog motor".
One of my best friends while growing up's mom had a "Monza Town Coupe" (same shape as a 3rd gen Celica Coupe) with a 305 - basically a factory V8 Vega. Too bad they only got the 305 option in CA.
« Last Edit: February 15, 2009, 12:52:39 pm by a2ndopinion » Logged
85GTS
Bronze Member
Hero Member
Rep: 11
Offline Offline
Wannabe Toyota collector- Oregon City, OR
View Profile
« Reply #13 on: February 15, 2009, 02:24:22 pm »
Well im not old or a chevy guy, and I knew about the 302.....
Logged
-Rebuilt engine (.040 over, engnbldr head, balanced)
-All new brakes (Brembo,KVR,Technafit)
-Impact6 FSB, old tscperformance rear brace
-Hella E-codes w/upgraded relays and wiring
-14" Elec. Fan
-5MGE 60mm TB
-Whiteline Sways
77 Celica GT Liftback "Stripes"
-20R-E powered!! (20R block, early RE head, intake and electronics from a '92 2wd hilux)
-RA65 Front sway bar
-ghetto home-made rear brace
-poly mm
1971 Toyota Corona "Toby"
-needs engine
-needs paint.... bad
1985 Toyota Cressida
-5MGE (for now)
-W58/F303
-100A Lexus Alternator (plug n play)
83GTCoupe
Gold Member
Hero Member
Rep: 3
Offline Offline
View Profile
« Reply #14 on: February 15, 2009, 03:57:21 pm »
Nope. Of course I have heard of the 427. Very sought after engine. I don't know a single person in my lifetime, that ever looked for a GM 302, or even mentioned one being in existence. Not only that, but it was never brought up in either of the two automotive schools I attended. The smaller V-8's such as the 283 and 305 were always talked about, but never a 302. Now to top it off, I have yet to have EVER come across a 302 GM in a yard, and I used to spend every weekend in the yards from the time I got my drivers license. I have yet to EVER see a GM 302 at the car shows, such as Carlisle, PA., or to even hear someone make mention of this "supposedly" popular engine.
Not once, in all of my subscriptions to Hot Rod Magazine, Car & Driver or any other magazines, did I ever see an article on this engine. cool Now, if the 302 was so popular, then why is it that so many people went after, and still go for the 327?
« Last Edit: February 15, 2009, 04:11:54 pm by 83GTCoupe » Logged
Pages: [1] 2 3  All
  Print
Jump to:
