Author Topic: W58 Celica Transmission from 22RE  (Read 9739 times)
Offline EZpickenZ
« on: Oct 06, 2010, 08:39:05 am »
PHONE NUMBER: *Optional*
EMAIL:  CECoggins350@yahoo.com
PAYMENT PREFERENCE:  Cash
ITEM:  W58 Celica Transmission from 22RE
PRICE:  $300 OBO
SHIPPING:  Local Pickup or Ship at buyers cost
DESCRIPTION:
I have a W58 transmission out of an 84-85 Celica GTS.  It shifts very well and has no grind.  It comes with the full driveshaft and clutch fork.
I also have a solid axle from the same car.  The diff has been welded and has stock gears.  $50 OBO
« Last Edit: Oct 06, 2010, 08:41:36 am by EZpickenZ »
Offline tig321
Re: W58 Celica Transmission from 22RE
« Reply #1 on: Oct 10, 2010, 04:30:17 am »
If this from a Celica, I believe it would be a W55 with a different shifter location and gear ratios than the W58 that came in the Supra.
« Reply #2 on: Oct 10, 2010, 05:38:55 am »
No, the Celica came with either a W50 (up to '81 IIRC) or W58 (after that), never a W55, that was in the trucks and 4runners. Whoever edited Wikipedia to include it is an idiot. However, I'm thinking this came from a Supra or something, the shifter and bell housing looks different from the Celica one, but I've only ever really looked at it from underneath, so I can't be certain.
« Last Edit: Oct 10, 2010, 05:40:35 am by ozzie »
Offline tig321
« Reply #3 on: Oct 10, 2010, 05:54:37 am »
The trans I pulled for my auto to manual swap came from an 84 celica and is a w55 and has the correct shifter location for the celica it came from. Bob, celica_83gts had a supra w58 for his 7m swap, it has different shifter location (it may be from a mkIII). The toyota's I've had were 4wd and had w56 transmissions.
Any way he could just check the build plate if he still has the car and check.
« Reply #4 on: Oct 10, 2010, 06:05:08 am »
The firewall tag said W55? It's nothing new to find a W55/W56 in a Celica, because the W58 blew up and they replaced it with a W55.  You can swap the tailshaft and bell housing and it'll be exactly the same dimesions as a W58, since a W58 is just a W55 with different gearing.
The W55 only came in the small 2WD trucks, W56 in 4x4s, heavier 2wds, and 4runners, sorry for the confusion.
Offline tig321
« Reply #5 on: Oct 10, 2010, 06:28:16 am »
maybe my brain is failing me (wouldn't be the first time) but I remember it being w55, when I pulled it. I just checked wiki and it says
W55
Applications:
    * 1982-1983 Toyota Carina
    * 1981-1985 Toyota Celica
    * 1983 Toyota Corona
    * 1986 Toyota Soarer
    * 1986 Toyota Crown
    * 1983 Toyota Chaser
    * 1984-1988 Toyota Pickup 2WD with 22RE(EFI) engine
    * 2002-2005 Lexus IS300 (US Market only)
I pulled it from a very low K car 86000 MI, and from the condition of the interior I believed that mileage. I wouldn't expect the trans to have been swaped. Now I'm going to have to check every w series car/truck when I go to junk yard next time. :heh: Don't trust wiki :glare:
Bump for a South Carolina W Series trans
« Reply #6 on: Oct 10, 2010, 08:06:33 am »
Yeah, wikipedia's full of shit, although the odd years they list (81-85) indicated maybe it came with the 21R on the aussie model? I dunno, but all USDM 3rd gen Celicas should have a W58 (if they have a manual), I know all 3 of mine do.
« Reply #7 on: Oct 10, 2010, 08:37:54 am »
+1 on wiki being full of it, especially since they are correct about when they say the W58 came in the IS300, and Toyota did mot use two different 5 speeds in the same year/model car, ever.
Offline EZpickenZ
« Reply #8 on: Oct 11, 2010, 09:31:31 am »
Sorry it has taken so long to reply.  I didn't have internet for a few days.
So,  looked all over the trans to find any ID, but didn't find anything.  the car is gone.  The engine had been rebuilt and i never asked if the trans had been changed b/c i needed the efi engine for my 4x4.  when i googled the images for the w55, w58 and w50 and I thought it looked more like a w58.  So, the w55 and w58 use the same housing?  Another question.  If this is a w55, is this trans a possible swap to the 4x4 or are the gears different?
W55
Applications:
    * 1986 Toyota Crown
If I have misled you i apologize.  What are the differences between the w55 and w58 so i may tell them apart? :help:
« Reply #9 on: Oct 11, 2010, 01:16:55 pm »
gearing will tell you for sure... spin the output shaft and carefully count the number of times the input shaft turns... or if you want to pull off the extention housing you can count the teeth on 5th gear...
87 Celica GT-S coupe "Zip"
Offline The84
  • Proud owner of a 1984 Toyota Celica GT Liftback.
« Reply #10 on: Dec 31, 2012, 07:25:47 am »
Is this tranny still available?
1984 Toyota Celica Liftback (RA64)
Price bought for: $1,000
269k
All Original 22R-E engine
Panda Style Paint Job
Fog Lights
Tofu Sticker
All Stock, Keepin' It OG
My first Celica
I drove her DAILY!!!
RIP :'(
154,000 miles
Clean interior
Original owners manual
Healthy motor and trans
Planning a manual swap and 22RE-TEC/ 1UZ-FE swap!!!
Daily Driver
Lowered
GTS Mudflaps
Celica Hatch Wing
« Reply #11 on: Dec 31, 2012, 07:56:02 am »
This thread's 2 years old...probably not.
« Reply #12 on: Jan 04, 2013, 04:40:46 pm »
Offline EZpickenZ
« Reply #13 on: Jan 04, 2013, 05:04:18 pm »
Even though this thing is 2yrs old, i still have the tranny. If you are interested, let me know.  The price is still $300 obo.
« Reply #14 on: Jan 04, 2013, 06:05:51 pm »
lol damn
