Author Topic: 1973 Toyota Celica - $300 (SE Portland)  (Read 2768 times)
Offline joezkurtz
« on: Nov 07, 2010, 07:53:50 am »
http://portland.craigslist.org/mlt/cto/2046056113.html
1973 Toyota Celica, does not run due to a bad carburator, other than that the car runs good. I put in new clutch 3 years ago, new starter, alternator, water pump. Good tags till 2012 and does not need to thru DEQ. There's minor dents on the front hood, other than that the body is clean as well as the title which I have. I'm asking 300 firm because this car is a classic and I do not won't to sell it, but I have no where else to store it. If your interested please call me at 5036887095. ask for Lue.
84 Celica Gts 268 engnbldr cam,dual electric fans,msd ignition with blaster coil,Tenzo 2.25 exuast,doug thorley headers
K & N air filter.15X8 in sportmax 002 wheels with kumho 225/50/r15s
Dorman Control Arms
Moog tie rod ends
Tokico Strut Insert
Addco sway bars front and rear
Dobinson Mk1 And 300lb Mk2 Springs
87 4Runner 22RE 2.7L Stroker
Lc intake kit,mild cam,4.88 gears,Lc off road clutch kit,Lc header,flowmaster 2.25 exhaust,gm alternator upgrade,upgraded gauges with side pillar,msd ignition with blaster coil 31in tires for now but wanna upgrade to 33s or 35s!
Re: 1973 Toyota Celica - $300 (SE Portland)
« Reply #1 on: Nov 07, 2010, 07:57:01 am »
Another one of those "the car does not run", but past that "the car runs good" postings, when will people learn how to post something for sale. :rolleyes:
Offline hsvrocketman
« Reply #2 on: Nov 07, 2010, 08:03:56 am »
My favorite is "the car runs out good".
What the heck does that mean?
Kevin
'80 Corolla SR-5 Liftback
'80 Fiat X 1/9
'85 Celica GT-S Liftback
« Reply #3 on: Nov 07, 2010, 03:00:52 pm »
Even not running its worth 300, unless its a major rust bucket underneath... Id be on this like white on rice in a blizzard if we didnt have 6 cars already...
87 Celica GT-S coupe "Zip"
Offline Coop301
  • '85 Ragtop - Kansas City
« Reply #4 on: Nov 07, 2010, 06:14:41 pm »
GONZO!
Offline joezkurtz
« Reply #5 on: Nov 07, 2010, 10:52:17 pm »
Sold!
Dorman Control Arms
Moog tie rod ends
Tokico Strut Insert
