Author Topic: manual transmission swap, complete part list  (Read 3191 times)
Offline Dr.Jun.Manabe
  • Fremont - San Jose, CA
« on: Dec 25, 2011, 06:59:11 pm »
just completed mine a few weeks back, thought id post everything you'd need in one place
5 speed w58 transmission out of a 82-85 celica (complete with 2xr bell housing, clutch fork, t/o bearing etc..)
shifter
top 2 manual trans bolts (automatic are too long)
clutch (if new, should come with new t/o bearing, pilot bearing and clutch alignment tool)
flywheel
flywheel/flexplate bolts (found that they are the same, still got arps though)
5 speed front half of the driveshaft
master cylinder
slave cylinder
clutch line (hard line/custom made line)  direct fit http://www.phase2motortrend.com/cispautomacl.html
auto/manual trans cross member (they are the same)
clutch pedal
clutch pedal support bracket or custom support bracket/bolts
manual car brake pedal
backing plate between motor and trans (auto backing plate works the same)
transmission supports that bolt to the motor from auto or manual trans, auto does work with the w58
cut out about an inch of the top of the shifter hole
i think thats it, if anything else post n ill add
some of my pics
sachs clutch :thumbs:
hope this helps anyone!
'85 Celica GT Liftback -Black Lighter- (Daily)
-Megan AE86 32-way coilovers, T3 RCAs, T3 lateral bar, Cusco front tower bar, custom rear tower bar, boxed LCAs, ES poly bushings, Cube Speed short shifter, Stoptech slotted rotors, EBC Yellowstuff pads, Technafit stainless steel brake lines, Tomei 1.5 Way LSD, Rota Grid V wheels, Cusco Bride Vios 3 bucket seat, Nardi Classic 340mm steering wheel, stock motor w/ SV3 test pipe, 2.5in exhaust, and a cone filter.
'85 Celica GT Liftback -Evangeline-
'84 Celica GT-S Liftback -Silver Bullet- *SOLD* will be missed
'85 Celica Supra P-Type -Lucrezia- (2JZ-GE swapped, broken)
'73 Plymouth Scamp
Offline TransAmBandit
Re: manual transmission swap, complete part list
« Reply #1 on: Dec 25, 2011, 07:26:39 pm »
I drilled my firewall when I mounted my clutch pedal. How did you do yours?
1984 Celica Supra P-Type - 5MGE, 5 Speed Swap, 2nd owner
1985 Celica GTS Vert - Currently being restored and swapped to 5 Speed and LSD
1986 Cressida - 5MGE/5 Speed Swap/LSD
1987 4Runner Turbo - 22RTE/Auto BHG.
« Reply #2 on: Dec 25, 2011, 07:29:48 pm »
the holes were already there on my 85 GT they had little rubber grommets you pop out for the master cylinder bolt holes.
edit: are you talking about the clutch pedal mount?
« Last Edit: Dec 25, 2011, 07:31:39 pm by Dr.Jun.Manabe »
'73 Plymouth Scamp
« Reply #3 on: Dec 25, 2011, 07:57:48 pm »
With mine (even though its an 81) I had to drill out the bracket, that the pedal bolts to, off the 76 and I still need bolt it on the 81 for extra support.
« Reply #4 on: Dec 25, 2011, 08:04:30 pm »
i just ended up using 2 long bolts, nuts and washers, an a drill, its very sturdy and has the right angle
'73 Plymouth Scamp
