Author Topic: Sway bar options - Whiteline Supra bar  (Read 866 times)
Offline fast_eddie_72
« on: Jun 30, 2013, 02:25:48 am »
I put a Whiteline Supra bar (part # BTF76Z)on the front of my Celica today. It fits surprisingly well! It has a unique end link arrangement and includes some brackets that bolt to the control arms. Looking at the instructions, I believe I have them flipped opposite the intended direction. With that "modification" it bolts on like it's made for the car. The mounting holes are back a bit further than ideal, but the end link arrangement makes it work fine. Just thought I'd share my experience in case anyone else is looking for an adjustable sway bar option. I'll let you know how it works out when I get it out to the next autocross.
Also changed out my springs. Lowered the car about 2" all around and went to (gulp) 1000 lb/in springs in the front. I really don't understand it, but the car was still rolling quite a bit with 800 lb/in springs. We'll see what happens. Ride on the street didn't change at all. The suspension doesn't do anything, it's all tire. But when I race, it still feels a little "boaty". Had to wait on a special order for the 1000 lb springs. Not sure if I can go any higher! But, hey, now I can say "I have a ton of spring in the front of the car".
Take care,
Ed
« Last Edit: Jun 30, 2013, 03:07:35 am by fast_eddie_72 »
Re: Sway bar options - Whiteline Supra bar
« Reply #1 on: Jun 30, 2013, 02:39:08 pm »
Good info, wonder what car it is for. If you up the spring weight that much but still feels squishy I think you need to look into stiffening the chassis. The Chassis probably flexes quite a bit.
« Reply #2 on: Jun 30, 2013, 09:18:39 pm »
I'm sure the chassis has some flex, but the car is just rolling a lot. Well, a lot for an autocross car.
« Reply #3 on: Jul 05, 2013, 04:29:43 pm »
what kind of chassis bracing are you allowed to do in your class? I think it's worth exploring since making the chassis stiffer can't really hurt.
Offline YNW.RA64
  • Young And Wild
« Reply #4 on: Jul 05, 2013, 05:59:22 pm »
have you ever heard of spray foam in your sub-frame? ae86 guys do it all the time just drill a couple small holes through out it and then spray the expandable foam into the "frame" on the car
1983 celica notch back - 268 torker cam, titanium valve springs, polished and ported, planned, air intake, special fuel system, 82 supra afm and mint mr2 seats modded on to stock gt seat rails. cat-less exhaust 2in to 2.5in
1969 chevelle malibu me and dad resto'd
collector plates
crate 350 aluminum heads cam intake double pump 650
headers
3 speed ratchet stage 2 shift kit post rear
« Reply #5 on: Jul 05, 2013, 06:24:10 pm »
I know in rocker panels it holds moisture to the inside of the metal, causing them to rust out extremely quickly...
« Reply #6 on: Jul 06, 2013, 02:01:28 pm »
there is a long topic on the polyurethane foam debate, pros/cons etc. I think it's one that I started :heh:
Offline firstgenrex
  • PDX - Second times a charm
« Reply #7 on: Aug 23, 2013, 03:57:49 pm »
Can I ask who you are having make the custom springs for you? I am wanting to do the 2" drop. I also have a GTS which will make a difference, thanks
'84 Celica GT-S Coupe 5-spd (white) 170k 3rd owner
Offline RwdCarNut
« Reply #8 on: Aug 24, 2013, 03:23:44 am »
I wonder if you upped your dampening(stiffer shocks) on both bump and rebound, if that would help make it feel less boaty. The high spring rate and floaty feeling screams under damped to me.
Shes Good from afar, but far from good
1984 Ra65 Celica 1991 22re Engnbldr 268 ect...
1996 Mazda B4000 4x4
Offline quagmire
  • Anything is possible.
« Reply #9 on: Aug 24, 2013, 03:37:32 am »
 :agree:  That extra mechanical energy is stored in the spring, turn it into heat in a damper.
1983/85 Celica GT-S Coupe RA65 EFI W58 374000 miles DeerSlayer
 • original engine no rebuild, new timing chains at 165115 and 367188 miles
 • "HOLY F@$% 358k on the stock headgasket?!?!?!?! Thats some voodoo magic ass shit right there" - AkiRA65
1980 Celica GT Series B Liftback 20R ATM - sold
OJCM Oldskoolerz
