Author Topic: 7mgte to 5mge turbo  (Read 2526 times)
Re: 7mgte to 5mge turbo
« Reply #15 on: Nov 29, 2013, 05:12:48 pm »
looking forward to your result, no one really spends much time on the 5M motor.
Offline tomsupra85
« Reply #16 on: Nov 29, 2013, 06:43:28 pm »
I would consider the 5mge under rated.Its better than the 7m way i see it.the best part of the 7mgte is the engine management so I'm going to combine the best of the two engines.Should be a real rev happy 250-300Hp engine.the dyno should be interesting .
Offline tomsupra85
« Reply #17 on: Dec 01, 2013, 04:54:00 am »
And so the build begins.the 5m is home
Offline 85gt22ret
« Reply #18 on: Dec 02, 2013, 06:07:57 pm »
should be a nice set up are you going to run a front mount intercooler. cause i didnt run one sence the 22ret doesnt come with it factory and thats why im in the middle of fixing my 22ret that i was boosting 13psi on and timing over adv. and broke the compression rings. will be nice to see what you make. after i get mine back together and 500 miles on it ill be dynoing as well. will be cool to see the number difference.
Offline tomsupra85
« Reply #19 on: Dec 02, 2013, 06:45:16 pm »
Yea front mount intercooler is in.
Offline Northern Redneck
« Reply #20 on: Dec 02, 2013, 07:28:42 pm »
Wanna trade?  :heh: nicely done.
85 gt-s red 22re w58 3.90 gears 7.5 irs
K and n open air filter mod
Msd coil and wires
Ngk iridum plugs
Louvers
84 gt-s 22re w58 6.7 irs
Parts car?
89 F150 black 2wd 302 h.o. Built aod 8.8 4.56 gears
In dash dvd player clarion subs alpine amp alpine speakers dual flowmasters headman headers edelbrock rpm air gap msd coil plugs wires 6al ignition box forged pistons roller cam cai painted block valve covers and oil pan looking to do an sefi swap
2009 G5 2.2 Vvt auto red
Bone stock ss exhaust 17 inch black widow rims on cooper zpt skins 235/45s
Pioneer deck speakers amp sub tweeters ipod integration
AAAALLLLLLLL FOR CLEATUS!!!!!!!
« Reply #21 on: Dec 02, 2013, 08:31:34 pm »
Can you post a video of it running/boosting?
Msd coil and wires
Ngk iridum plugs
Louvers
Parts car?
Offline tomsupra85
« Reply #22 on: Dec 02, 2013, 08:59:23 pm »
Yea its in the works.my oil/water burning 7mgte is still in the car and despite the engines condition it still burns tires at freeway speed.
Offline 85gt22ret
« Reply #23 on: Dec 03, 2013, 06:14:00 pm »
can you up load pic of when you did your front mount im about to do it and would be kool to see how yours was done also do you have the specs on the size of the intercooler?
Offline tomsupra85
« Reply #24 on: Dec 10, 2013, 12:13:14 am »
Well my intercooler is 25"x12" i could use a bigger one.I welded tabsa to the back side of the bumper. and bolted it in.
Offline 85gt22ret
« Reply #25 on: Dec 12, 2013, 09:24:43 am »
25x12?????? The biggest I measured out was 18x12x3
Offline 85gt22ret
« Reply #26 on: Dec 25, 2013, 08:03:27 am »
25x12 that the core ? Or the out side of the tanks
Offline warpigg
« Reply #27 on: Dec 26, 2013, 06:49:44 pm »
how is this quick build going because I always thought about running a 5m with a turbo  since they don't have all the problems the 7m's have with the headgasket problems an such. I just never knew what to do for engine management. so im interested to see how you are going to use the 7m computer.
83 celica gts ~ engine builder reworked head with O/S valves and 270 cam ~ hogged out intake plenum with a 5mge throttle body to a open filter on a probe afm ~ obx header with full 2.25 exhaust ~ cusco/240 strut tower bar ~ looped power steering lines
« Reply #28 on: Dec 26, 2013, 08:46:12 pm »
Someone at one point built a killer 5M turbo, but it blew up. I wish I could remember where I'd seen it, or what the point of failure was.
AFAIK, the 7M head gasket issues pretty much go away if you up the torque.
« Reply #29 on: Dec 26, 2013, 09:44:51 pm »
Fastest 5mge I've heard about was in the 10's it had an old standalone ecu and coil on plugs, upgraded cams, no idea what happened to it.
Msd coil and wires
Ngk iridum plugs
Louvers
Parts car?
