Author Topic: Mkii Supra Gear Ratios  (Read 8395 times)
Offline Tanya
« on: Aug 23, 2004, 07:23:05 pm »
Supra gear ratios (mkII)
1982 3.72 standard gearing in both automatic and 5 speed
1983 4.10 available for the 5 speed, auto still 3.72
1984 4.10 available for the automatic, 4.30 for the 5 speed
1985/1986 same as 1984
CODES to look for:
F303 = 3.72 limited slip
F302 = 3.72 non limited slip
F293 = 4.10 limited slip
F292 = 4.10 non limited slip
F283 = 4.30 limited slip
F282 = 4.30 non limited slip
USDM Supras all P-types have LSD, all L-types have non-LSD
In Canada, the Supra GTS (P-type) and GT (L-type) do not seem to follow this rule, keep an eye out for the codes
« Reply #1 on: Aug 28, 2004, 08:46:45 pm »
Rock on..that means that the 83 supra rear end I am getting will give me 4:10 gears, I was wondering what it was...
Offline Tanya
« Reply #2 on: Oct 13, 2004, 12:41:06 am »
could this perhaps be made a sticky or something as this is one of the more repeated questions I see?
Offline dynamic73
    • Dynamic73 Racing
« Reply #3 on: Oct 13, 2004, 10:11:39 am »
Don't forget the F312 which is a 3:90 out of the 85 Celica and the 85-88 Cressida's.
"IF YOU RACE IT...IT WILL BRAKE"
Offline ahhstockduu
    • http://www.myspace.com/88rx7
« Reply #4 on: Oct 13, 2004, 10:41:00 am »
do you guys have anyinfo for the mk1. us solid ppl need some info too.
i have 78 supra auto in mine. but i dont know the gearing. any clue?
Offline Tanya
« Reply #5 on: Oct 13, 2004, 12:12:47 pm »
Well I did that write up on mkII Supras only if you didn't notice
 :P
If someone else wants to do the research on the Celicas and mkI Sup, you're welcome to it, you can PM me and I will edit this thread or you can make it known elsewhere. The differential codes/ratios are widely needed info apparently
Offline SonyPete
« Reply #6 on: Oct 13, 2004, 08:29:30 pm »
I know this isn't a supra rearend question, but the search feature is screwin up badly. But what is my gear ratio with an 83' Celica Automatic, is it a 3.72 since that what the supras had in 83' on the auto?
1983 Celica GT with Built-for-Boost 22RE
Current Mods:
- Forged CP Pistons, Prepped Rods, ARP Head Studs & Rods Bolts
- Lightened & Knife Edged Crankshaft
- Compcams 127-4, 82' Supra TB and AFM
- DT Header and 2.25" Under Axle Exhaust
- 12" Electric Fan
Offline OldMage
  • Guru of Useless Tidbits
    • http://celica-gts.com/users/oldmage
« Reply #7 on: Oct 13, 2004, 10:37:04 pm »
Check your VIN plate on the firewall.  Across the bottom are codes for Color/Trim - Axle/Trans.  The axle for your Celica is most likely a "T372" which means it's a non-LSD 3.583:1 ratio.
'83 Celica GT-S coupe - EFI hybrid
'03 Prius - DD/corner-carver
My Home Page My Photobucket
Offline SonyPete
« Reply #8 on: Oct 13, 2004, 10:49:24 pm »
Damn that would be really low if thats teh case.  I bet I would get a hefty jump in acceleration just by getting a 3.72 or maybe a 4.10 but my revs would be ridiculous at 70 to 90 mph, right?
« Last Edit: Oct 14, 2004, 12:55:01 am by SonyPete »
Current Mods:
- 12" Electric Fan
« Reply #9 on: Oct 14, 2004, 02:03:11 am »
Yep, pretty much... Mage's car tops out at about 110 with his 4.10s, that's redlining.. My car has 3.42's (stock 82-85 GT and all GT-S's until 85..) and can easily top 100 in 4th..
« Reply #10 on: Mar 08, 2005, 11:51:16 pm »
Hey I was wondering if the ring and pinion are interchangable between the gts celica models and supras. I am looking into getting a LSD from a supra for my celica but I like the gearing that I have now. Thanks
87 Celica GT-S coupe "Zip"
Offline NightCelica
« Reply #11 on: Mar 09, 2005, 01:59:09 am »
The non-85 GT-S(ST and GT too) Celica all had the 6.7" diff, while the 85 GT-S 5spd Celica and all MKII Supra received the stronger 7.5" diff.
The MKI Supra had a 8.1" diff, you swap in the whole alxe over to a ST or GT MKIII Celica and bolt it on.
I have wondered about the truck alxes, but I have not the specs.
« Reply #12 on: Mar 09, 2005, 02:14:57 am »
I'm pretty sure the first gen supras use 7.5" F code axles  :unsure:
« Reply #13 on: Mar 09, 2005, 02:39:58 am »
So if I found a supra LSD I could just bolt it right into my celica?
« Reply #14 on: Mar 09, 2005, 02:42:21 am »
It depends.. not *ALL* 85 GT-S's got the bigger diff... Check the plate on your firewall for the diff code.. If it starts with F, it's the big one. If it starts with T, it's the small one. Another indicator is your RPM at 60mph in 5th.. If it's around 2100 RPM, it's a T code, if it's around 2700, it's the bigger one.
