Why our you replacing your head gasket? is it blown?
The biggest is removing you exhaust manifold, it unbolts from the head just fine, but getting to the three bolts at the collector are a pain in @ss, so much so that when I did my I removed the bolts from the cat. and pulled the exhaust manifol and down pipe out throught the engine bay. it was easier than trying to get to those three bolts.
Be very careful with the studs on the exhaust manifold they brake very easily, I would replace them with new ones to be in the safe side. Clean the threads for the head bolts and the exhaust manifold, I would use a tap&die to do this plus it has a added benfit of making sure the threads are in good shape, but be very careful when using the tap+die so that you do not cross thread it, us lots of oil(clean) and air to blow out the stud holes.
The next is making sure you got all the bolt in the under side on the intake manifold, for those that have removed the thier intakes before know what I mean.
There a is special type bolt on the intake manifold that goes throught the themorsat housing. Buy that tool before starting any thing it is a large allen(I think that what it is called) type head.
Make sure the chain does not slip off the crank gear, you will not be able to see the crank gear but if you use a piece of wood between the chain to keep tension on the gear.
I also had trouble with the power sterring pump when I was bolting back in place.
