First On Recall Day
Found On Road Dead
Fu*kin Old Rebuilt Dodge
Found On Ripley Dump
Fix Or Repair Daily
Flip Over Read Directions
Fast Only Rolling Downhill
Fumes Only Rarely Deadly
Suppose I shouldn't say much, I'm driving an '89 Aerostar with only 120k on the clock, and the only issues it's had are a crapped out fuel pump, doors that broke and broke the window motors because the conversion company (Wagon Wheel) cut the crap out out of them, a couple corroded switches that needed to be cleaned, a broken piece in the dash that means I need to pull the cover off the dash to switch from heat to cold air, but that doesn't matter much because the AC's completely empty, surprisingly little body work, just rocker panel on one side, a leak in the back doors by poor design (barn doors), taillights that allow the light socket to fall out, bad ball joints, broken front springs, blown muffler, an auto transmission that's on its way out, low oil pressure below 1,500rpms that I still haven't figured out how to fix...okay, maybe I should have continued.
