Author Topic: 85 Convertible Top Trouble Shooting  (Read 11733 times)
Offline santos
« on: Jun 23, 2007, 12:32:14 am »
i have a 1985 toyota celica convertible with brand new top. i hooked up the motor direct and top goes up and down real nice have to put the back seats down manually. but no power to the switch anyone have instructions on how to diagnose the problem? maybe pics on relay and fuse locations?this would help me out big time
thanks
« Reply #1 on: Jun 23, 2007, 01:07:31 am »
The relay, and breaker for the top are on the driver side kick panel fuse box. The relay is the black box just above the round relay, all the way forward on the fuse box. The breaker can be removed, and reset if it's still good, and placed back in the fuse box.
Offline santos
« Reply #2 on: Jun 23, 2007, 03:37:50 am »
hey that helps out alot is there away to test the relay and circuit breaker?
« Reply #3 on: Jun 23, 2007, 07:56:35 pm »
You can use a multimeter for testing both. The raly should make a noise though when powered up. It should make a clicking sound when engaging and disengaging. The breaker has a small hole in the face that you can put a paperclip into to reset it. Do a continuity test on it to make sure that you have a closed circuit.
Offline santos
« Reply #4 on: Jun 24, 2007, 05:34:37 pm »
i tested the CB and relay and both have continuity.but i hear no clicking on the relay not even with stethescope.anyway i was wondering should i be able to get power or test the area the CB or relay goes in?
« Reply #5 on: Jun 24, 2007, 08:01:53 pm »
Are you putting power to the relay coils? You'll hear the relay click when there is power to the coils...
Check for power at the terminals where the relay and CB are with the switch on or off.
Offline santos
« Reply #6 on: Jun 25, 2007, 08:23:20 pm »
thanks to all of you has responded with help. i bought new relays and  CB still no luck.i stuck my multimeter in the prongs and i get 12v but when i tried to get voltage at the switch it was 0. :wall:  i couldnt find the other relay on the rightside of steering column. are there any safety switches i need to know about maybe something was disconnected?
« Reply #7 on: Jun 26, 2007, 10:53:55 pm »
I'm not familiar with the location of the switch for the vert tops, but it sounds like you have a cut wire somewhere. You may have to trace the wiring from the fuse block to the switch, and thoroughly inspect it. Was there an aftermarket stereo and/or alarm system added to it?
Offline santos
« Reply #8 on: Jun 27, 2007, 01:09:22 am »
there is an aftermarket stereo, thanks to all for the help i appreciate it  :D i am closer to solving this problem because of you guys
« Reply #9 on: Jun 28, 2007, 08:28:59 pm »
Santos, any updates? Where is the top switch located? I would assume (which I don't like to do) that it's in the center console, since that's where the majority of the knockouts and switches go. If that's the case, and there's an aftermarket stereo, then they may have smashed the wiring, or accidentally cut it, or worse yet, used it for powering an amp or CD changer.
Offline santos
« Reply #10 on: Jun 28, 2007, 08:38:55 pm »
i havent located the problem as of yet and you are correct on the location of switch. i am planning to work on it this weekend thanks for the help and concern
just picked up a ae86 ive been working on and my te72
« Reply #11 on: Jun 28, 2007, 08:40:40 pm »
Cool mang. Keep us up on the progress. :thumbs:
Offline santos
« Reply #12 on: Jun 29, 2007, 07:47:37 am »
traced the wires from the switch to a relay called the main relay.opened it up and everything seems to be working or nothing looks burned.but i am gonna try and get one at the parts recycler.hope i finally tracked the problem :cross:
« Reply #13 on: Jun 29, 2007, 02:48:44 pm »
Good deal. It should be a standard relay. Any car that has the power windows, sunroof, door locks etc, should use the same relay, so 82-85 Celica, and 82-86.5 Supra should supply you with what you need. Those same relay's can be found under the hood fuse block, as long as it wasn't raided. ;)
Offline santos
« Reply #14 on: Jun 29, 2007, 11:08:11 pm »
i wish it was a standard relay
« Last Edit: Jun 29, 2007, 11:08:57 pm by santos »
