Welcome,
Guest
Login
or
Register
Home
Help
Search
Members
Login
Register
Celica-GTS.com Message Forums
General
Suspension & Brakes
Gts Control Arm Info
Print
Pages:
1
2
3
All
Author
Topic: Gts Control Arm Info (Read 9827 times)
warpigg
Senior Member
Re: Gts Control Arm Info
Reply #30 on:
May 16, 2014, 03:05:56 pm »
I'm pretty sure welding spring steel is a no no and search all your awnsers can be found
Logged
83 celica gts ~ engine builder reworked head with O/S valves and 270 cam ~ hogged out intake plenum with a 5mge throttle body to a open filter on a probe afm ~ obx header with full 2.25 exhaust ~ cusco/240 strut tower bar ~ looped power steering lines
85gts22re
Newbie
Reply #31 on:
May 21, 2014, 03:13:20 pm »
Putting spring steel on it is good because it will flex and not break. U prolly suck at welding. Once the tags run out im driving it to the junkyard. These cars rot away so easyily. Good luck finding parts
Logged
ozzie
Senior Master
Reply #32 on:
May 30, 2014, 05:19:54 am »
Spring steel becomes very brittle after welding, and probably won't provide much in the way of reinforcement. Just go down to the local hardware store and pick up a steel bar to do the job.
Logged
Northern Redneck
Senior Member
Reply #33 on:
May 30, 2014, 05:02:00 pm »
Just keep an eye out, you will find some good ones, I'm dead into the rust belt,our cars see more winter conditions then summer and I managed to find a complete rear end for $400 it's solid all the way through and it's an lsd with 4:10s
Logged
85 gt-s red 22re w58 3.90 gears 7.5 irs
K and n open air filter mod
Msd coil and wires
Ngk iridum plugs
Louvers
84 gt-s 22re w58 6.7 irs
Parts car?
89 F150 black 2wd 302 h.o. Built aod 8.8 4.56 gears
In dash dvd player clarion subs alpine amp alpine speakers dual flowmasters headman headers edelbrock rpm air gap msd coil plugs wires 6al ignition box forged pistons roller cam cai painted block valve covers and oil pan looking to do an sefi swap
2009 G5 2.2 Vvt auto red
Bone stock ss exhaust 17 inch black widow rims on cooper zpt skins 235/45s
Pioneer deck speakers amp sub tweeters ipod integration
AAAALLLLLLLL FOR CLEATUS!!!!!!!
AJM85GTS
Newbie
Reply #34 on:
Apr 20, 2015, 11:10:57 pm »
I see the last post here is from last summer, but - anyone have a line on these control arms?
I've scoured the net with little success. Maybe i'm just NTFS. Here's what happened to my passenger side...
Logged
79 Celica 5spd ST vinyl roof - miss it!
87 2wd pickup 5spd - really small inside!
85 GTS coupe 5spd- refreshing/restoring
85 GT hatch 5spd- faster than my other celicas, no idea why
07 FJ Cruiser - best vehicle ever. Really. I miss it.
11 Scion tC - that stands for Toyota Celica, right?
ozzie
Senior Master
Reply #35 on:
Apr 21, 2015, 03:26:30 am »
Quote from: AJM85GTS on Apr 20, 2015, 11:10:57 pm
You're a windows NT file system?
Logged
Print
Pages:
1
2
3
All
General
Suspension & Brakes
