Author Topic: Why Must Our Wiring Be So Fucked?  (Read 983 times)
Offline Celica4mea
    • http://www.geocities.com/frague3796
« on: Sep 21, 2003, 08:32:00 am »
I dunno about you guys....by my cars wiring has been suspect lately....like the E-brake light and the light for the battery are like intertwined.....and when I dont have my headlights on.....when I push on the brakes my console and dash light up.....and stuff like that........and now my stereo wont work.....dunno why yet.....and i think my battery/alternator problem is likely due to wiring! UGH......damn wires!
Mods:
K&N
Supra AFM
Shaved intake plenum
Relocated Fuel Filter
Modded Throt. (no cruise)
1mm O/S valves
Stage 2 Cam
Rebuilt Head
40 Overbore
Rock pistons
Ground & Polished Crank
Resized rods
OEM Clutch Kit
Reground/Lightened Flywheel
Timing kit (steel guide)
Pacesetter header
2.25" header back exhaust (no cat)
Remus muffler
Strut Tower Brace
Hella H4 Conversion Headlights
Shortened Shifter
New: Every gasket/bearing/ring/washer, H2O Pump, Oil Pump, Alternator, Starter, Battery, Timing Cover
« Reply #1 on: Sep 21, 2003, 09:12:06 am »
Well the wires are just a little old. But I have noticed problems with mine quite a bit too.
« Reply #2 on: Sep 21, 2003, 01:55:18 pm »
On the Toyotas, when the alternator is on its way out, the brake light and alternator light will come on as a warning. I would suspect your alternator either has a bad regulator, rectifier or short brushes.  I would start my search here
« Reply #3 on: Sep 21, 2003, 02:22:37 pm »
It could be that or your batt charge relay is going out. When I first got my car the brake light would not shut off and the charge warning light kept coming on. I took the relay out and tested it....it was dead. Went to the j/y and got a good one, changed them out, and viola! No more problems..
Offline toynado
« Reply #4 on: Sep 21, 2003, 05:44:27 pm »
that console deal sounds like a bad ground or crossed circuits
(wire that should be on separate fuses crossed, making a new, erroneous circuit with the current running the wrong direction)
but i imagine it's just a wiring fault
cuz i'm not familiar with the wiring
but i know they use switches on the negative or ground wire on some circuits
sounds rather lame
and the headlight wire is insuffient
if you re do it with correct wire/relays the lights get much brighter
Offline Culpeper
    • http://www.myculpeper.com/1982celica/
« Reply #5 on: Sep 23, 2003, 02:41:42 pm »
I've a had a few minor problems with wiring in the past.  I think I read a review somewhere once that claimed our wiring needed improving.  Nevertheless, electrical problems on any old vehicle comes with the territory.
1982 Celica ST Coupe
Offline Pimp Cat
« Reply #6 on: Sep 24, 2003, 08:59:20 pm »
my alternator light comes on at random times yet it has a brand new alt and the battery is still charging at 14v
:confused:
