Author Topic: 22-rte  (Read 983 times)
Offline PooRLiLGT
22-rte
« on: Sep 22, 2003, 05:10:11 am »
What year 4-Runner came with the 22-RTE?
I think I got screwed on my panda paint job...
http://www.cafepress.com/fuckshoes
22-rte
« Reply #1 on: Sep 22, 2003, 06:25:16 am »
i think they started in 86... and your little kung fu guy is wrong.. hes got my ISPs IP and im using Opera ^_^
22-rte
« Reply #2 on: Sep 22, 2003, 08:35:29 am »
His little guy is pretty close to me. I use af.mil and using win2k and ie5.. :ph34r:
« Last Edit: Sep 22, 2003, 08:35:52 am by 83CelWA »
Offline toynado
22-rte
« Reply #3 on: Sep 22, 2003, 10:44:57 am »
wut the **** is a meat popsicle?
is that a reference to david bowie...
i thot he wuz a robot
Offline toynado
22-rte
« Reply #4 on: Sep 22, 2003, 11:07:44 am »
86-88 or 87
i forget
wuz in pickups too
any 22re 'lazer' block can be modified to work
just drill thru the block for the oil tube
piece of cake, the block is all set up for it
here's a email off the toymods list today about
mr2 vs supra turbos
Supra CT26 has a larger compresosr wheel, same A/R
compressor housing (as far as I know)
Identical turbine wheels
Supra exhaust housing has considerable larger A/R
ratio
Stock Mr2 250 rwhp max
stock Suprra 325-350 rwhp max (best guess)
Its mainly because of teh exhaust
housings. No matter what anyone has done to teh
compressor side of the CT26 no one has gotten reliably
past 280 rwhp because of a restrictive exhaust
housing.
If you put a Supra exhouast housing on an MR2 you can
cross teh 300 rwhp "barrier" but will have a fairly
laggy turbo because of the larger A/R.
i seen 350 hp turbo 22re's
and 750 hp 22re's
22rte
Offline Bridge
  • I get all the girls
    • Facebook Profile
22-rte
« Reply #5 on: Sep 22, 2003, 07:25:40 pm »
Those trucks are pretty rare though. I've only recalled seeing one turbo 4Runner and one turbo PU. And the engines are even harder to find.
-2002 Subaru WRX-
22-rte
« Reply #6 on: Sep 22, 2003, 07:34:37 pm »
Yeah they were prone to turbo failure. I know some people swapped out those engines.  I believe there is a truck on Ebay right now, located somewhere in Florida
Offline PooRLiLGT
22-rte
« Reply #7 on: Sep 23, 2003, 04:49:17 am »
www.toyota-automotive-store.com sells rebuilt 22-RTE long blocks with a 7 year/70,000 mile warranty for $1,610.
« Last Edit: Sep 23, 2003, 04:50:41 am by PooRLiL'GT »
Offline dynamic73
    • Dynamic73 Racing
22-rte
« Reply #8 on: Sep 23, 2003, 06:33:06 am »
That's a really good deal for a long block. Even better that it's a turbo engine. If you want to build a turbo engine. You need a turbo block and head. I'd have to know what kind of internal parts he puts in them. But it still sound like a really good deal. Might be worth checking into.
"IF YOU RACE IT...IT WILL BRAKE"
Offline PooRLiLGT
22-rte
« Reply #9 on: Sep 23, 2003, 06:39:25 am »
All long blocks come with cylinder head(s) attached and valve train installed. Valve covers, timing cover, intake manifold and oil pan are not included.
All long blocks have NEW valves, valve springs, valve keepers, push rods, rocker arms, fulcrums, lifters, camshaft, timing chain (belt), timing gears, valve guides (diamond honed), three angle seats, cam, rod and main bearings, pistons, piston rings, rod bushings (if applicable), gaskets and oil pump.
All cylinder blocks, cylinder heads, crankshafts and connecting rods are cleaned and shot peened and magnafluxed for cracks. All bolt holes are tapped.
Cylinder blocks are bored to each piston and diamond honed to 18RMS finish. All oil galleys are hand brushed with white cleaning brushes and cylinders are hand cleaned with cleaning solution and white towels.
Cylinder heads have each valve guide diamond honed, seats are three angle. After assembly, heads are vacuum checked for valve seating.
Crankshafts are ground and polished to 12RMS. Each oil galley is hand brushed with a white cleaning brush.
All connecting rods are honed.
ALL OUR REMANUFACTURED LONG BLOCKS MEET OR EXCEED ORIGINAL
EQUIPMENT SPECIFICATIONS
- New Manley valves
- New Elgin valve springs and keepers
- New Badger pistons
- New Hastings molly rings
- New Dynagear timing gears and Durabond cam bearings
- New Dynagear timing gears and chain
- New Elgin lifters, push rods, rockers, balls and nuts
- New Dynagear oil pump
- New FelPro gaskets
- Cylinder heads are pressure checked
- Diamond honed valve guides
- Three angle cut valve seats
- All head surfaces are broached
- Blocks are bored with deck plates, cylinder walls are diamond honed
- Crankshafts are ground and polished for .002 clearance
- Camshafts are ground to O.E.M. specifications, hardened and polished
- Connecting rods are sized to .002 clearance
22-rte
« Reply #10 on: Sep 23, 2003, 12:33:17 pm »
That is a great site...Now maybe after I get my car built up to how I want it I will be able to get a better engine for it also..
