It works folks. Took the plunge and now my air conditioner for my 1985 Celica GTS using R12 is now COLD. For the 1st time in over 20+ years of me owning this car, last year, the air conditioner just stop giving me my usualy cool air. I was worried due to the lack of supply of R12 and the environment. I guessed my entire system was generally fine, but somehow the R12 may have found a way to escape. So performing the filling below, I assumed it was completely empty. I did notice my compressor was still kicking in. The site glass was showing bubles. Here is what I did. As usual Disclaimer: use at your own risk, wear protective gear, googles (supplied), cap, gas mask and cover your arms. I'm just anal about safety when it comes to something I'm not sure of.
1) Bought the Duracool kit from a Canadian Walmart, kit included everything except the refrigerant. 3 cans, 1 eye goggle, adapter and gauge. It costed me $99 Can. I also bought two Duracools refrigerant for $14.00 each. Total cost: $130 Can.
Here are the kit contents:
1.1) I also bought two cans of the Duarcool Refrigerant.
2) what I did 1st was remove the LOW side cap from the compressor. Shown here on the right side:
3) removed the cap, and connected the supplied brass adapter that just screws onto it.
4) pierced the Duracool can, and connected to the adapter, and followed the instructions. Let it out slowly, car is not running.
The can I used 1st was:
Waited for several minutes while slowly opening the tapper valve. Then started the car and air conditioner. the compressor started and clicked in several times. I again slowly continued to let more refrigerant in the system.
When it was empty, I repeated the process with the other cans.
5) Used the Duracool DuraDry Can. Which is supposed to remove the moisture within the air conditioner system.
5) used the Duracool SystemSeal Can, which is supposed to assist in general sealing of the air conditioner system.
6) this is how it looks while filling the system, should be a bit more upright than that, but I had to still take the photo.
In order of cans used: Duracool, DuraDry, DuraSeal. It comes with a Duraoil Chill can, but I didn't use it.
I'm one happy camper now. I will keep you posted if anything changes. Otherwise for further info, go to their site.
http://www.duracool.com/You know me, I don't like to advertise, but if it works for me this Gen of Celica using R12, I'm sure you can find some use for it.
Good luck.
For now, I'm feeling just COOL
