Welcome,
Guest
Login
or
Register
Home
Help
Search
Members
Login
Register
Celica-GTS.com Message Forums
Miscellaneous
The Lounge
Another Test!
Print
Pages: [
1
Author
Topic: Another Test! (Read 1127 times)
Celicasrule
Full Member
Another Test!
on:
Sep 25, 2003, 12:05:55 am »
:o
:D
<_<
Logged
83CelWA
Senior Master
6M Celipra GT-S
Another Test!
Reply #1 on:
Sep 28, 2003, 06:33:05 am »
Logged
Celica4mea
Forum Master
Another Test!
Reply #2 on:
Oct 02, 2003, 03:54:53 am »
oogity boogity
Logged
Mods:
K&N
Supra AFM
Shaved intake plenum
Relocated Fuel Filter
Modded Throt. (no cruise)
1mm O/S valves
Stage 2 Cam
Rebuilt Head
40 Overbore
Rock pistons
Ground & Polished Crank
Resized rods
OEM Clutch Kit
Reground/Lightened Flywheel
Timing kit (steel guide)
Pacesetter header
2.25" header back exhaust (no cat)
Remus muffler
Strut Tower Brace
Hella H4 Conversion Headlights
Shortened Shifter
New: Every gasket/bearing/ring/washer, H2O Pump, Oil Pump, Alternator, Starter, Battery, Timing Cover
Celica4mea
Forum Master
Another Test!
Reply #3 on:
Oct 02, 2003, 03:58:53 am »
hmmmmmm
Logged
Mods:
K&N
Supra AFM
1mm O/S valves
Stage 2 Cam
Rebuilt Head
40 Overbore
Rock pistons
Resized rods
OEM Clutch Kit
Pacesetter header
Remus muffler
Strut Tower Brace
Shortened Shifter
83CelWA
Senior Master
6M Celipra GT-S
Another Test!
Reply #4 on:
Oct 10, 2003, 02:02:05 pm »
Logged
dynamic73
Forum Master
Another Test!
Reply #5 on:
Oct 29, 2003, 09:40:56 pm »
Logged
"IF YOU RACE IT...IT WILL BRAKE"
83CelWA
Senior Master
6M Celipra GT-S
Another Test!
Reply #6 on:
Oct 30, 2003, 06:41:36 am »
It's called boredom......
Logged
AE86er
Junior Member
Another Test!
Reply #7 on:
Oct 30, 2003, 07:50:15 am »
What's up freaks...hahahaha it's ur old buddy (SUCK MY CARBS) don't know me well too bad!! <_< i had a celica once if i showed you pics u might just DAMN!!!!
well that will be for next time. till then see ya!!
Last Edit: Oct 30, 2003, 07:51:16 am by AE86er
Logged
'87 Corolla GT-S Coupe "Battle ready setup anytime kid"
'87 Corolla SR5GT-S Coupe "Daily w/LSD & Suspension"
"as i gain experience,your headlights get dimmer in my rear view mirror"
formerly: SUCKMYCARBS '85 RA65 GT-S w/45mm webers .nuff said
PICs
http://f1.pg.photos.yahoo.com/weber45mm
83CelWA
Senior Master
6M Celipra GT-S
Another Test!
Reply #8 on:
Oct 30, 2003, 08:53:28 am »
Wassap Nino...welcome to the forum, hopefully you will stay with us for a bit since you know some about the celi's.....oh yeah how is th eae86 coming along anyways?
Logged
Celica4mea
Forum Master
Another Test!
Reply #9 on:
Oct 31, 2003, 09:53:30 pm »
Im just repsonding to this cuz them my name is in all 4 main forums haha Im a tard
Logged
Mods:
K&N
Supra AFM
1mm O/S valves
Stage 2 Cam
Rebuilt Head
40 Overbore
Rock pistons
Resized rods
OEM Clutch Kit
Pacesetter header
Remus muffler
Strut Tower Brace
Shortened Shifter
Print
Pages: [
1
Miscellaneous
The Lounge
Another Test!
