Author Topic: Factory Service Manual  (Read 10604 times)
« on: Dec 31, 2008, 06:28:16 pm »
Offline Dougs85GT
  • Currently celica-less R.I.P. Puff :(
« Reply #1 on: Dec 31, 2008, 08:36:49 pm »
Bookmarked.
This should be sticky'd  :thumbs:
Offline IIonPilgrimg
Re: Factory Service Manual
« Reply #2 on: Jun 11, 2010, 06:09:53 pm »
One of these days, I may scan my FSM for a 1984 Celica.
The '84 has slight differences from the '85. For instance: the thrust-washers...
The crank is the same in both but the blocks require a different thickness of TW.
IIonPilgrimg -- 1985 Celica GT-S Convertible, 5sp; 1987 Toyota 4Runner SR5 22RE/5sp -- at the moment, that's all my Toyotas
Offline 91stxman
« Reply #3 on: Sep 09, 2010, 10:21:15 am »
1st link is dead
buy my stuff http://www.celica-gts.com/forums/index.php?topic=21011.msg335512
85 CELICA GT-S BEST CAR EVER PERIOD 94 celica stx (40mpg highway) 87 toyota truck (project)
« Reply #4 on: Sep 09, 2010, 06:45:30 pm »
1st link is dead
Must've been an issue with the server, working fine now.
« Reply #5 on: Dec 08, 2010, 10:59:09 pm »
i noticed if you go back one you get more info for the trucks
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Offline 85GTSeugene
« Reply #6 on: Jan 12, 2011, 04:27:19 am »
awesome link! thanks!! :biggrin: :biggrin:
Offline 45psi
« Reply #7 on: Oct 10, 2014, 09:47:25 pm »
Anything for the chassis? GTS
« Reply #8 on: Oct 10, 2014, 09:52:46 pm »
Yep, posted the one I spruced up a few months ago.
« Reply #9 on: Jul 24, 2016, 06:03:10 pm »
Digging up an older thread here... even though it's stickied too. The link provided for the FSM throws a "404 not found" error. Anyone have an updated link or a copy of the FSM which they could put on Google Drive or Dropbox or something?
Mia the '91 Miata - Revived Twice! (263k); BP-5A 1.8L swap, an NB in NA clothes
Lilith the '94 Legend GS - The New Smooth Daily™ :shades: (150k)
Lude the '95 Prelude Si - The Dead Tweaker Queen (237k)
Offline Dr.Jun.Manabe
  • Deez Bitches Rollin'
« Reply #10 on: Sep 13, 2016, 08:41:09 pm »
Use wayback machine.
https://web.archive.org/web/20150418023924/http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine.html
'85 Celica GT Liftback -Black Lighter- (Daily)
-Megan AE86 32-way coilovers, T3 RCAs, T3 lateral bar, Cusco front tower bar, custom rear tower bar, boxed LCAs, ES poly bushings, Cube Speed short shifter, Stoptech slotted rotors, EBC Yellowstuff pads, Technafit stainless steel brake lines, Tomei 1.5 Way LSD, Rota Grid V wheels, Cusco Bride Vios 3 bucket seat, Nardi Classic 340mm steering wheel, stock motor w/ SV3 test pipe, 2.5in exhaust, and a cone filter.
'85 Celica GT Liftback -Evangeline-
'84 Celica GT-S Liftback -Silver Bullet- *SOLD* will be missed
'85 Celica Supra P-Type -Lucrezia- (2JZ-GE swapped, broken)
'73 Plymouth Scamp
