thought i would share this with you guys on here, im not sure if you even got the RT142 Corona though.
so anyway, the RT142/ST141 in Australia came with disc and drum IRS and disc and drum SRA. so you have like a
1 in 4 chance of finding one here that has the disc SRA rear end.
first you need to remove the wheels.. (duh)
crab a 10mm spanner and undo the brake line that is bolted to the back of the diff near the shocker mount.
once that is off you need a 14mm spanner to undo the 2 bolts on the back of the caliper.
take them out and the caliper will come off.
now that the caliper is out of the way you should be able to remove the disc, make sure the handbrake is off and
remove it.
next you will need a 14mm socket and extension bar to undo the axel bolts, you get to them through the access holes
in the end of the axel. once that is done pull the axel all the way out and dont put it somewhere where its
going to roll on to the road!.
the backing plates should be hanging down at this point and only the handbrake cables will be left. just unbolt
the cables from the body and in the middle of the car they come apart just like a bike cable or accelerator cable
comes off.
once that is off you should have the disc, caliper, backing plate and both handbrake cables.
you can if you want, also grab the brake hard line from the back of the diff. if you dont you will
have to cut the line and use a flaring tool to make it work. not a big deal and is easy as hell.
your probably better off buying new disc's and pads. but im cheap so i didnt lol.
now obviously you need to remove all the drums.
its just like i mentioned above but a little different.
remove wheel.
remove the drum brake cover thing (has that thing actually got a name lol)?
undo the brake line on the back of the backing plate
undo the axel bolts
pull out axel
unbolt handbrake cable
and remove backing plate with handbrake cable connected.
then you just put the disc's on the same way they came off of the other car and you have Disc's on your SRA
