Well, it won't *bolt* on, but if you were careful about it I imagine you could, in theory, use a spot weld cutter to cut the welds from the forward subframe to the chassis on both cars. It would be a more time consuming process to cut them, but it would make up for itself when reassembling, and IMO you'd be much more likely to end up with a quality product vs a hack job.
