Author Topic: Sound Clip Of My Car  (Read 1818 times)
Offline ToyotaRacingTeam
    • http://www.lompocperformance.com
« on: Oct 03, 2003, 11:08:40 pm »
84 Celica GTS
Open air intake, 2.5" catback with 4x9 aluminized magnaflow case muffler, non resonated tip, see pics at www.sounddomain.com/id/3rdgenbeast
page4 has it.
http://mywebpages.comcast.net/truenolevin/...-Maganaflow.wav
« Last Edit: Oct 03, 2003, 11:12:42 pm by ToyotaRacingTeam »
Tim Neuman
RS/GT Racing Founder
1968 Chevrolet El Camino
Offline Celica4mea
    • http://www.geocities.com/frague3796
« Reply #1 on: Oct 03, 2003, 11:15:44 pm »
nice! sounds almost exactly like mine cept mines a bit lower!!!! I like the not too ricey sounds!
Mods:
K&N
Supra AFM
Shaved intake plenum
Relocated Fuel Filter
Modded Throt. (no cruise)
1mm O/S valves
Stage 2 Cam
Rebuilt Head
40 Overbore
Rock pistons
Ground & Polished Crank
Resized rods
OEM Clutch Kit
Reground/Lightened Flywheel
Timing kit (steel guide)
Pacesetter header
2.25" header back exhaust (no cat)
Remus muffler
Strut Tower Brace
Hella H4 Conversion Headlights
Shortened Shifter
New: Every gasket/bearing/ring/washer, H2O Pump, Oil Pump, Alternator, Starter, Battery, Timing Cover
« Reply #2 on: Oct 03, 2003, 11:17:33 pm »
thx
Tim Neuman
« Reply #3 on: Oct 03, 2003, 11:18:42 pm »
Sounds nice.  That is the way an engine should sound. None of this mosquito crap
« Reply #4 on: Oct 03, 2003, 11:20:22 pm »
:D
Tim Neuman
« Reply #5 on: Oct 04, 2003, 12:12:07 am »
btw, if it werent for the quality of the file id bet my car would sound exactly like urs, it sounds so much deeper in person, makes ya wanna cream urself.
Tim Neuman
« Reply #6 on: Oct 04, 2003, 04:19:54 am »
That's how I would like my car to sound. I am going to be very carefull when I upgrade my exhaust so it does not sound like a ricer..
Offline PooRLiLGT
« Reply #7 on: Oct 04, 2003, 04:10:35 pm »
Yeah I like that sound!
I think I got screwed on my panda paint job...
http://www.cafepress.com/fuckshoes
« Reply #8 on: Oct 04, 2003, 04:18:15 pm »
:D  :D  :D  :D  :D
Tim Neuman
Offline toynado
« Reply #9 on: Oct 04, 2003, 05:52:15 pm »
tell me yor muff is not 9" long total
sounds a little raspier than my raptor, but hard to say
your xhaust is stock to the cat?
did you notice any low end loss with the catback?
« Reply #10 on: Oct 04, 2003, 06:43:00 pm »
18" long, 24" if u count the inlet and outlet, yes its stock to the cat, got no loss in low end torque, nothing noticible anyways. the exhaust doesnt sound raspy at all in person, damnit i need a stereo microphone, the sound quality blows balls with this clip, im gonna try to make a better sounding clip later, see if where i position it gets a better effect.
Tim Neuman
Offline toynado
« Reply #11 on: Oct 05, 2003, 04:52:20 am »
i think the truck peepl with their 2 1/4" xhaust logic are wrong
so now i have to re do my xhaust AGAIN
glad i didn't buy an expensive muffler
they think 2 1/2" robs backpressure and some low end power
there's no power down there to start with
loonz
e b, who makes hp mods for the 22re still thinks the STOCK MANIFOLD is as good as a header
he increases the pipe size to the exit
it makes for nice flo theory
but i say it's wrong
mine cracked at the y downpipe anyway
why replace that decrepit thing?
it's cheap used i guess
« Reply #12 on: Oct 05, 2003, 06:33:28 pm »
Hmmm, my exhaust sounds deeper then that, and there isnt any raspiness to it... the glasspack makes it sound kinda hollow though, i wish i had a mic to record it with...
« Reply #13 on: Oct 05, 2003, 06:53:27 pm »
i wish i had a stereophonic microphone to record mine with so you guys would stop saying mine isnt low damnit.
Tim Neuman
« Reply #14 on: Oct 05, 2003, 06:56:14 pm »
btw people, the raspiness is wind and my intake, both are pretty airy sounding and believe me, u can still hear my intake frmo the back end over the exhaust at high revs.
Tim Neuman
