Quote I was wondering, is it ok to just remove the cat and run it to the muffler, I was told that if its got a cat, you need to keep one on, because it will be harmful on the engine without it To my knowledge, the cat is for SMOG purposes only.
I was thinking about getting one of those bypass valves. You weld it in before your cat and you can welp a pipe that bypasses the cat then you've got a lever you can pull and make it either run through your cat or bypass your cat and whole exhaust.
Thought so, still better to use a dummy cat if you are afraid of the law.
