Due to the heat when racing and the wide 275 tires that block a lot of the air, I had to install some cooling ducts on my Celica. This is how its done. You need the following parts:
2 ea brake cooling scoops large size Pegasus racing part # 3626-black $26.99 ea
Brake duct hose 3" diameter (need only 2 ft but it comes 6 ft) Pegasus racing part # 3620-3.00-6 FOOT $37.49
You can sub other 3" hose as long as it is fairly stiff.
2 ea hose clamps
2 ea 3" adel clamps Mcmaster.com part # 8863T93 $1.77 ea
About 20" of 3/4"x1/8"steel flat bar.
Screws as shown.
Some aluminum sheet 10 ga.
Remove the air dam. Then hold them up to fit into position so that the straight side runs along the frame rail to get the idea. It will stick out past the side of the fender.
Now cut some flat bar into strips about 10" long. Drill and tap holes 8-32 for screws as below and weld these to the bottom of the bumper as shown behind the area for the air dam. They run roughly parallel to the front of the car.Paint em to stop rust.
Use the flat bar as a guide to drill holes in the scoop to match. Use wahsers or button head screws to attach.
