Okay, a few tips and hints.
Test the motor again once you have it back together to make sure you didn't screw anything up. Next, the arm that connects the motor to the actual headlight assembly will just pop off. If you take the time to unscrew it, you will just create more work for yourself. If you do not have it adjusted properly when you put everything back together the motor will not work right. Trust me, I know... Just pop it off and you don't have to worry about adjusting it when you put it back together.
One thing I forgot to take a picture of was the inside of the 83 motor I used for spare parts. It was caked and packed with dielectric grease(spelling??) I would and did repack the gear and motor before putting back together. The grease will help with both keeping corrosion at bay and keeping water out. On keeping the water out, there are two O-rings in the motor. One is between the contact wheel and the cover and the other is between the gear arm and the back cover. I did not replace or renew either O-ring, doing so would probably help extent the life of the motor.
I will strip out one of my other 83 spare motors tomorrow night to take some pics and show the O-rings and the grease.
Thanks for moving, and yeah, realized that last night...
Here is the inside of the 83 motor from the other side of the car.
Notice how nice and clean the ring is. The gloss is the grease coating everything. This one is still a bit too dry for my tastes.
Here is the large O-ring that I mentioned in the earlier post. A competent mechanic would have replaced this as well.
There is also a small O-ring where the shaft from the arm gear meets the back of the housing. I again, chose not to replace this, unlike any decent, competent mechanic... You can replace this small O-ring after you have the gear back in the housing. the O-ring is actually installed from the outside.
