That is a Contour Roam - Contour just released the Roam2, which isn't very much different, so you should be able to pick one up relatively cheap. A quick Amazon search shows them going for $129, whereas they were $199 before (I picked mine up new for $86 last xmas with a killer coupon discount). With the Contour, any programming needs to be done with it connected to a PC, but to start recording all you have to do is slide the button forward. It only takes about 1 second to start, records in HD (@ 30fps) & is waterproof to 1 meter without a case. They also have some pricier models that let you bluetooth out the video to a smartphone or are GPS enabled.
