Author Topic: Nothing pretty build thread  (Read 46209 times)
Re: Nothing pretty build thread
« Reply #435 on: Jul 18, 2017, 03:46:03 pm »
For OEM naca ducts look no further than a 280zx. 79-83. They are functional too. And well made.
« Reply #436 on: Jul 18, 2017, 07:01:00 pm »
I've used those in the past, as well as the 280Z flat hood grill/vent, but they're getting to be harder to find.
T-bird turbo coupe hood vents used to be a favorite of mine as well (used as a scoop on the turbo chicken)
eBay has a whole slew of NACA ducts ( <-link) that could be made to work.
The thing about NACA ducts though, is that they offer no real advantage, that I've read about, as a vent.  As a scoop, yes, they can take in air without adding drag, but no real "vacuum" effect as a vent.
BTW - July 22nd is Portland Cars and Coffee JDM day.  Not sure, but I might bring the Celica out.
I was thinking something like this near the sides of the hood where water won't dump on anything moisture sensitive
« Reply #437 on: Jul 18, 2017, 07:31:40 pm »
Yea, whatever fits your needs for venting. I think you can flip a naca duct around so that the narrow end is pointing downstream to create a vent effect, but not much reason to when there is positive pressure on the other side. Probably why you still see race cars use traditional louvers when venting.
Terran should pipe up, this was his field I thought or at least he studied some fluid dynamics :biggrin:
Offline silverliftback
« Reply #438 on: Jul 18, 2017, 07:51:43 pm »
Red Celica hood in the PDX Pick-n-Pull?  A small silver lining perhaps to the end of nkryption's GTS:
http://www.celica-gts.com/forums/index.php?topic=30323.0
1985 Celica GT-S liftback 5sp (2016-2018, sold)
1990 Celica Alltrac (2019- )
« Reply #439 on: Jul 18, 2017, 08:13:33 pm »
ouch didn't think about that.
« Reply #440 on: Jul 18, 2017, 09:59:16 pm »
Sad panda on a cool thread.
« Reply #441 on: Jul 19, 2017, 02:25:16 am »
That looks like the one: http://row52.com/Vehicle/Index/JT2RA65L0E0006097
On a side note, the thing is already fairly well stripped.  Suspension, fenders, flares, and engine are (or were) still there.  Nypher got the dash and radiator (as well as a bunch of other stuff) while I was there
« Reply #442 on: Jul 19, 2017, 04:08:21 am »
The crazy thing is, we could've gotten most of this stuff for nearly free and likely helped this guy out.
« Reply #443 on: Aug 06, 2017, 11:44:13 pm »
Well fawk.  I started removing some mangled metal today to prep for a bash bar install (so I can mount my Corrado bumper).  It's been mangled since I bought the car and never thought much of it.
This is what it should look like
This is what mine loos like after I drilled all the spot welds holding the mangled metal on
The front cross member isn't even attached on the driver side.  I can push on the frame rail with my foot and see it move  :ohmy:
So the next project is a custom front cross member made from 2"x3" .080" thick rectangular tube (stock metal is only .045"), new lower radiator mounts, caster rod mounts, and new skid plate (all that stuff is tied to the front cross member).  That'll also give me a chance to make a much more stout bash bar mount
« Reply #444 on: Aug 07, 2017, 04:49:06 pm »
So it was the cause from previous damage or all celicas look like that when you remove the outer sheet metal in that area?
« Reply #445 on: Aug 07, 2017, 05:06:23 pm »
corax's car looks like that because of crash damage prior to him getting the car I assume
« Reply #446 on: Aug 08, 2017, 12:57:29 pm »
This is all accident damage from before I got the car.  The metal from the crossmember which overlaps the top & bottom of the frame rail was torn from day one.  Today I'm gonna take that same metal piece off the other side (no damage), so I'll see how it's supposed to be attached.
« Reply #447 on: Aug 08, 2017, 02:50:07 pm »
coo, hopefully it's a lot better.
« Reply #448 on: Aug 13, 2017, 02:34:31 am »
oops, something fell off the front of my car (after many spot welds were drilled)
so this is kinda my main issue in this project - the frame rail has a pretty good crease in the side of it and the top is bulged up where I need it to be flat to weld the crossmember in
but some progress was made today anyway - there's no way for me to get the crease out of the frame rail, but the new crossmember will bridge it and provide rigidity, front of both frame horns were cut off as well.  I didn't really plan it, but the sheet metal to either side of the radiator opening follow the new piece almost perfectly - about 1mm gap on the side which isn't mangled.  Still need to add some gussets front & rear as well as the piece which sits on top of the frame rail.
« Reply #449 on: Aug 13, 2017, 03:57:36 am »
If you wanted to get rid of that crease, I would cut a 2x4 down to fit inside the frame rail, with a bit of an angle on the end to force out the crease gradually. Ideally the angled part would have a piece of 1/8"+ thick flat stock on it to give it extra strength. Then just hammer it in. In the worst case scenario, it fails, but is stuck in the frame rail, so you cut off the 2x4 at the end of the frame, and then drill holes in it with a spade bit until its in pieces small enough to pull/vacuum out.
