this is what I started with today - an old style intake that Toyota used for nearly a decade and an overly complicated throttle linkage with a bunch of slop in it. I didn't
have to change to the linkage to install the upper manifold, but I wanted to.
I put this TB bellcrank, from an early 90's 4 cyl 4runner (22RE) on the throttle body after trimming off the upper cable bellcrank (the crescent behind the pushrod linkage ball). Note that the ball is the same distance from the center hole as the linkage that's currently on the throttle body - it could be used with the pushrod linkage. Also, the center hole is already rounded from the factory (not slotted) so it can be rotated on the TB shaft. This is how it looked originally.
I imagine any late 80s 22RE "cable only/ no pushrod" bellcrank could be used
I was almost able to just use the bracket that came on the new upper intake manifold (no pushrod linkage), but found I ran out of cable adjustment & had to space it back .5" - I cut the upper cable mount (for cruise control) off & welded it into position. First I adjusted the bellcrank on the TB shaft so the throttle plate is wide open with the pedal completely mashed into the floorboard, then I adjusted the cable so there is just a little bit of slack in it at idle.
The new upper manifold didn't have a nipple for the Aux. Air Valve since Toyota changed over to a throttle body mounted cold idle system when they used this intake. So I bought a .5" O.D. brass nipple and tapped pipe threads into the right spot on the manifold. The manifold is only about 1/4" thick so careful work with the 1/4" pipe thread tap is in order to prevent it from being loose and becoming a vacuum leak. There are no thicker areas that I could have tapped, or I would have and just routed a new hose from the nipple to the AAV. A bit of JB Weld doesn't hurt either. A screw type hose clamp is necessary to make the original hose seal to the nipple (original nipple is .550" O.D.)
Finished product, everything fits just fine. The accelerator pedal moves a bit more freely & this project allowed me to Simplify and Add Lightness
