« Reply #2 on: Apr 24, 2013, 06:59:59 am »
aboard!
I'm with ozzie on that. Go to engnbldr.com and get his steel backed timing chain set - and the top end gasket set.
If you're looking to increase power, while doing the timing chain, get a little porting work to the head and oversize valves with a good valve job, and a cam from engnbldr as well (either the 268 or not advertised 270). This will wake it up significantly! You can then can add exhaust later for even more.
Logged
