Author Topic: Wheel Fitment  (Read 32087 times)
Offline OldMage
  • Guru of Useless Tidbits
    • http://celica-gts.com/users/oldmage
Wheel Fitment
« Reply #30 on: Jan 04, 2008, 06:53:57 pm »
Thu the 3rd?  I wasn't home all day.  Was working on a lady's PC.
'83 Celica GT-S coupe - EFI hybrid
'03 Prius - DD/corner-carver
My Home Page My Photobucket
Wheel Fitment
« Reply #31 on: Jan 04, 2008, 08:24:09 pm »
We can't hold their hand and take them to buy wheels.
that's why when i was searching around and came up on this thread i was like, why isn't this a sticky, lol.
Offline Red85Celica
  • Silver Member
    • http://www.cardomain.com/memberpage/272671
Wheel Fitment
« Reply #32 on: Jan 07, 2008, 10:34:42 pm »
Not really sure I want to continue the off-topic "necro" of this thread... But I can't figure out where I'm "arguing w/ myself". Yeah, I didn't go back & edit things to condense the info or remove references from other threads/conversations...
 :lol: nevermind, I think I am the only one that found it funny. I was aware you hadn't gone through and edited.
Offline medeiros2021
Wheel Fitment
« Reply #33 on: Jun 07, 2008, 04:19:42 pm »
So all in all as long as the backspace, the distance from the back edge to the mounting surface stays the same you shouldn't run into loading problems, you just need to watch for rubbing? right
General Motors: Because somebody has to build rental cars.
Turbo Rotaries: 60% of the time, they work every time.
DSM: See crank. See crank walk. Walk crank, walk.
SRT-4: Because high 14's = low 12's on the internet.
"Racin'...always in good fun."
"Don't take life too seriously, you'll never get out alive."
"I'm Sean Medeiros, 'nuff said.”
"Cornell Racing...where freshmen go to learn the difference between metric and standard crescent wrenches and somehow build a winning racecar by senior year...those rats!"
Offline toyman22r
Wheel Fitment
« Reply #34 on: Nov 11, 2008, 05:17:30 am »
I've got chrome 17x8 inch with 4 on 4.5, 125 backspacing and +12 offset they fit perfect. with a 215-45-17 tire they are the same height as factory tires.
Wheel Fitment
« Reply #35 on: Nov 11, 2008, 05:52:27 am »
Don't just talk about it, show us the pictures! :poke:
Offline thesteve42
Wheel Fitment
« Reply #36 on: Nov 18, 2008, 01:14:31 am »
i just need to know if i can run 235/60r14 on the front of my gts vert?
MOD's custom transmission (A46DL...sort of it didnt exist until I built it): 16" electric fan (aftermarket, modified to fit) with temp probe and relay KIT. moved temp probe to bottom tank of radiator...the fan works much better now.
EB268c camshaft, 2" cat back exhaust, steel backed chain guide (got tired of braking guides)
replaced rear springs with MOOG MOG-5604 with 2.5 turns removed
Offline OldMage
Wheel Fitment
« Reply #37 on: Nov 18, 2008, 05:52:49 am »
Don't see why not.  Teranfirbt's run 235s for some time now
Offline CheGTS
Wheel Fitment
« Reply #38 on: Mar 04, 2009, 11:55:15 pm »
found some rims from Rota but can I go 8.5 wide?
Wheel Fitment
« Reply #39 on: Mar 05, 2009, 12:08:47 am »
With a GT-S, if the offset is right, then yes.
Offline OldMage
Wheel Fitment
« Reply #40 on: Mar 06, 2009, 09:43:14 pm »
Wow, I'm going to have to clean this out.  Not really s'posed to be a 'discussion' thread.  At least *I* thought it was for posting information to answer FAQ's
Offline CheGTS
Wheel Fitment
« Reply #41 on: Mar 17, 2009, 12:18:35 am »
for 8.5" wide rims will +4 offset work then?   (I know its got to be close)
Offline kurbkilla
Wheel Fitment
« Reply #42 on: Jun 23, 2009, 03:28:29 am »
ok im really rally confused and i need help, i dont like going to tire companies cuz they dont know our cars.  im looking at getting tenzor DC-6 but im unsure as to the off set.
also i want to use the car for drifting so will i have a problem with it being to wide?
i have an 83 celica gt
Wheel Fitment
« Reply #43 on: Jun 23, 2009, 04:24:25 am »
As far as the offset goes, those are FWD rims, the offest's a little much (they'd be tucked under the fenders in good shape). Stock offset is +8mm, 15mm doesn't look bad, nor do centerlines. Dunno about width for drifting.
« Last Edit: Jun 23, 2009, 04:25:17 am by ozzie »
Offline kurbkilla
Wheel Fitment
« Reply #44 on: Jun 23, 2009, 04:46:15 am »
would i have a problem turning...like hitting the inner wall?
