There are mercury switches on the inner two back seats. Those mercury switches have to be tripped and are done so by the rear seats folding down. Otherwise I would look into verifying the pump unit has fluid. The relays near the pump are working, the main relay (above the steering wheel and behind the cluster gauges) works, the neutral start switch is functional (if automatic), convertible top switch is not bad...
