I decided to jump in head first and cover the welds and shit with fiberglass filer like I have wanted to for a while to seal any missed holes. Plus a lot of it is low/uneven so It is the start of evening it all out. One day ill go back and do some proper body work over everything. For now the plan is slather it up with fiberglass filler. Sand it a little bit smoothish more or less just to knock down any bits of fiberglass sticking up weird and stuff, then cover with rattle can primer and paint like the other side as a rust prevention measure untill I can "One day" come back and do some body work and make it pretty. I got lucky and got 2 good quality grinder wire wheels for free from work which made stripping off the primer so much easier than I thought it would be.
I got one load of filler on right before it got dark
I then decided fuck it I'm going to set up a light and at least finish covering it with filler.
As AVE would say I do my best work in the dark. Of course it rained all day today and this work is stinky and messy so I have to do it outside. Anyway I still need to seam seal and undercoat in the wheel well and sand a little then primer/paint. Then I can make rear fender flares out of some garden edging I found in the garbage.
