It's been a long time. I've been distracted by this dang aluminum can on wheels
But it's quite fun to mod this little guy. Still learning new stuff so I can properly apply what I learn on the Celica.
I've since put in new shocks, springs all around and widened the rear track to be closer to the front track width. Also shimmed the rear wheels to reduce some of the toe in.
Replaced my worn out control arms with new ones, but took out the fat soft rubber on the trailing portion and stuck in a poly bushing.
Built a new transmission utilizing the first gen Civic Hybrid case and Honda Fit gearing to get rid of the horrendously tall gearing in the car.
I had to make my owner puller tool to check thrust clearance on the main shaft. Damn you honda.
I was missing some of the front underbody aero bits so I picked up one of these one pieces that another Insight owner makes.
My stock wheels were looking pretty haggard to me and when I saw a deal for some 14" Volk CE28s (6.5lbs!) I had to snag them up.
I deleted the rear wiper since it always felt pretty useless whenever I would use it.
The headliner started to come down so I put on something a bit more fun
This is my first time doing a head liner and I have to redo it, but still fun.
I still have a laundry list of things I got for it, but it's all fun. And yes, those ugly welds are still holding just fine after all these years and I've hit some pretty hard bumps too, one time I hit a pot hole that shook the car so violently that my can of fix-a-flat went off in the trunk.
