Welcome,
Guest
Login
or
Register
Home
Help
Search
Members
Login
Register
Celica-GTS.com Message Forums
General
Engine & Drivetrain
Ford 8.8 goodness started!
Print
Pages:
1
3
4
5
Author
Topic: Ford 8.8 goodness started! (Read 11496 times)
swan song
Forum Master
Enter Final Phase
Re: Ford 8.8 goodness started!
Reply #60 on:
Jun 10, 2018, 02:22:02 pm »
Hot diggity Ozzie, Thanks! That’s not bad at all for customer axles. They would be even stronger than OEM, retain the factory bolt pattern, and you can get them both in the length you want.
Good find dude!
Logged
Want a low budget LSD?
http://www.celica-gts.com/forums/index.php?topic=29189.0
ozzie
Senior Master
Reply #61 on:
Jun 11, 2018, 01:53:32 am »
And you wouldnt need to find an extra short side axle, and you can shorten to any length you want.
Logged
swan song
Forum Master
Enter Final Phase
Reply #62 on:
Jun 11, 2018, 05:46:55 am »
While we’re at it, here’s the performance rebuild for the trac lock lsd:
https://www.cjponyparts.com/ford-racing-traction-lok-rebuild-kit-with-carbon-fiber-clutch-packs-8-8in-1986-2014/p/M4700C/?year=1997&gclid=EAIaIQobChMI_bvQiPPK2wIVUb7ACh0u5g0fEAQYAiABEgJTvvD_BwE
It’s about as cheap as it comes for a carbon fiber clutch pack.
The ford part number is M-4700-c, it is literally the same clutch pack as the ones used in the Shelby GT500 and Cobra R.
Here’s the process:
http://www.therangerstation.com/tech_library/rebuild_tractionlock.shtml
Logged
patwhac
Full Member
Reply #63 on:
Sep 20, 2019, 11:38:53 pm »
I know this is an old (and awesome) thread, but I do have a related question. SwanSong, do you know or did you measure the stock pinion offset on your Celica? I'm not talking about pinon angle, but horizontal offset side to side. Most cars have some sort of offset built in to match how the engine/trans is mounted. If I ever get a custom housing this is a figure I'd need. Here's a guide to the whole topic:
https://www.dragzine.com/tech-stories/pinion-offset-guide-and-how-to-with-chassis-engineering/
If no one's measured yet on an SRA Celica, I will do it and post!
Logged
1987 Toyota Corolla GTS Coupe (AE86) - Drift Car/Daily Driver:
https://www.youtube.com/watch?v=tkXSZUJG3A0
1970 Skylark - Buick 350 Twin Turbo Build:
http://v8buick.com/index.php?threads/patricks-twin-turbo-350-build-thread.344770/
*Rear Ended and Totaled*
1982 Celica GT-S - Daily/Occasional Track Car:
https://www.celica-gts.com/forums/index.php?topic=30921.0
swan song
Forum Master
Enter Final Phase
Reply #64 on:
Apr 30, 2021, 03:55:35 am »
Pinion is centered L&R on the ra64
Logged
patwhac
Full Member
Reply #65 on:
Apr 30, 2021, 03:31:27 pm »
Quote from: swan song on Apr 30, 2021, 03:55:35 am
Heh heh I can't believe it's been almost 2 years since I asked
But nonetheless this is great info, thanks!!
Logged
Print
Pages:
1
3
4
5
General
Engine & Drivetrain
