Author Topic: Last one last 3 years  (Read 56098 times)
Re: Last one last 3 years
« Reply #1485 on: Oct 19, 2017, 09:38:42 pm »
You might be able to do something like that with todays tech. Honestly Id probably just have a jet heater for getting it up to temp quickly then just run the furnace to maintain heat. simple yet effective.
« Reply #1486 on: Oct 19, 2017, 09:53:03 pm »
pssh the pond if for jumping over in various noisy gas powered things.
« Reply #1487 on: Oct 20, 2017, 02:13:39 am »
Dammit. Now I need to build derelict bridges with ramps and model General Lees.
Remote control for the furnace really isn't a big deal. It's got a mobile home style oil furnace, so all I need to do is run some wiring up to the house to interrupt the signal from the thermostat. Just means I need to run 2 or 3 CAT5 cables instead of 1. Either that, or control it with an arduino, and use one of the various home automation apps available to control it. Then I could even turn it on while I was on the way home.
« Last Edit: Oct 20, 2017, 04:54:29 am by ozzie »
« Reply #1488 on: Oct 20, 2017, 02:43:26 am »
« Reply #1489 on: Oct 20, 2017, 03:29:26 am »
Any of you guys listen to the Kibbe and Finnegan show?
« Reply #1490 on: Oct 20, 2017, 02:53:12 pm »
No, but I'll be checking it out now. I like Finnegan on MT.
« Reply #1491 on: Oct 20, 2017, 09:37:40 pm »
Got a text from my real estate agent that someone else was planning on putting in an offer on that house, so I also put one in. I had hoped to go take a second look tomorrow, guess that's not happening.
« Reply #1492 on: Oct 21, 2017, 12:43:56 am »
Aaaaargh!!!!!! I just want to buy a damn house!
They took the other offer. :wall:
« Reply #1493 on: Oct 21, 2017, 01:11:31 am »
Man, I hate getting involved in bidding wars...  :dry:
« Reply #1494 on: Oct 21, 2017, 06:03:55 am »
Damn that sucks, there will be another nice place for you.
« Reply #1495 on: Oct 21, 2017, 11:33:39 am »
It wasn't meant to be. The one will come to you in time.
« Reply #1496 on: Oct 22, 2017, 05:44:17 am »
I've spent a few days now fixing the manifold on my dad's beater Escape 3.0L V6. This thing is in terrible shape and not really worth dumping a lot of money into, so at $250 (damn integrated cats), neither one of us were anxious to buy a new manifold. The manifold is built more like a header, with 3 individual flanges for the exhaust ports and mild steel tubing, not cast iron. So, the first issue was that the gasket was leaking, so we pulled the manifold to replace it. After getting it off, we found a T shaped crack, running both down the weld line from the last bank to the o2 bung, and also about 1/2" away from the weld line. So, after welding that up, I decided to have a closer look at the leak on the old gasket and the manifold flange, and it was obvious leaking from both the front and rear cylinders. Then I put a straight edge across the flange, and sure enough, the middle flange sticks out about 1/8" from the other 2. After debating a couple options, I put it on the belt sander :) After a couple hours (HF belt sanders suck!), it's close enough to flat that I think the gasket will take care of the rest. I really hope it all works, I'd hate to have put in all that work just to have to replace the manifold anyways.
On the housing front - I think I'm going to drag my real estate agent to go look at a couple that are just outside my price range, and if I like them, I'll put in offers of what I can afford and see if they bite. It's probably a no-go, but at this point, there's nothing else on the market in the area I'm really interested in.
« Reply #1497 on: Oct 22, 2017, 09:20:42 pm »
oooooo, 100 pages!
