Author Topic: 1UZFE SWAP  (Read 6234 times)
Offline 2FastforChu
  • How Do I Fix This?
Re: 1UZFE SWAP
« Reply #15 on: Jul 26, 2016, 02:32:51 am »
Does anyone know if I can use the celica fuel pump or do I have to upgrade to a aftermarket fuel pump
1985 Toyota Celica Gts
1UZRA65
Finally Got my Ca Plates
Re: 1UZFE SWAP
« Reply #16 on: Jul 26, 2016, 03:16:06 am »
Celica fuel pump works fine. You will need to run it straight, DO NOT connect the secondary fuel pump driver from the ecu. The Lexus has a two speed pump. The Celica is a one speed pump. If you connect FP from the ecu to your fuel it'll die under throttle.
Also the fuel filter won't work, so swap to a "universal one" or one from a dodge caravan.
You REALLY, REALLY, REALLY need to read the 1uz swap thread in the write up section. All of your questions are answered there. Well, 99% anyway.
Offline 2FastforChu
Re: 1UZFE SWAP
« Reply #17 on: Jul 28, 2016, 02:11:06 am »
instead of crimping the two power steering lines together would the excessive manufacturing power steering line kit work? and  motor mounts use stock ls400 motor mounts or buy new ones ?
1UZRA65
Re: 1UZFE SWAP
« Reply #18 on: Jul 28, 2016, 04:05:24 am »
supposedly
Contact Rich Kubhila at excessive. He at one time told me it would, because Toyota steering racks use the same size fitting for the power steering line. I believe the difference in the excessive line is the length. I'm looking into this too, as I live in BFE, and a hydraulic shop probably doesn't exist in my area.
Offline 2FastforChu
Re: 1UZFE SWAP
« Reply #19 on: Jul 28, 2016, 05:54:46 am »
i ordered it so it should be here by friday so i can give the fourms a answer
1UZRA65
Re: 1UZFE SWAP
« Reply #20 on: Jul 28, 2016, 02:01:11 pm »
pair Borgeson -AN to 16mmx1.5 inverted flare adapter
Aeroquip AQP high pressure power steering hose
Aeroquip AQP hose ends
Less than $100 can get you a custom power steering hose, just have to spend a few minutes to put it together yourself.  It's pretty easy, there are a bunch of tutorials online.
AN-6 is fine for the high pressure power steering line.  RA6x steering rack high pressure hose is 16mmx1.5, so are most of the Toyota power steering pumps that I've seen. Make sure you use STEEL hose ends specifically for Aeroquip AQP.  A bit of teflon tape on the inverted flare fittings is cheap insurance.  Funny thing - the power steering pump on my 3S originally had a banjo fitting, but it has an inverted flare seat in the banjo bolt hole and the inverted flare adapter fitting sealed just fine
Swan, if you need any custom hydraulics, check out Oil Filter Services in PDX - great place, they can even make custom steel braided brake lines
Re: 1UZFE SWAP
« Reply #21 on: Jul 28, 2016, 04:06:27 pm »
Re-he-he-heally??? Thank you sir!
Re: 1UZFE SWAP
« Reply #22 on: Jul 28, 2016, 10:56:57 pm »
and you can use this if you ever need to adapt TO an inverted flare fitting
http://www.speedwaymotors.com/O-Ring-to-Inverted-Flare-Power-Steering-Adapter,24682.html
Re: 1UZFE SWAP
« Reply #23 on: Jul 29, 2016, 05:07:30 am »
That piece is 10$!
Offline 2FastforChu
Re: 1UZFE SWAP
« Reply #24 on: Jul 30, 2016, 08:52:50 pm »
damn ups screwed up my order it was supposed to go to california from Oregon not Kentucky so another 2 days  :disgust:
1UZRA65
Offline 2FastforChu
Re: 1UZFE SWAP
« Reply #25 on: Sep 04, 2016, 09:23:11 pm »
Hey guys 1 month ago i tested the urethane motor mounts and they didnt fit so when you guys go on excessive get the series 10 mounts do not get the mx72 mounts even tho they say it's compatible. I now have to go reorder some series 10 mounts for the ra65
1UZRA65
Re: 1UZFE SWAP
« Reply #26 on: Sep 05, 2016, 01:47:00 am »
Your supposed to call Rich directly. He will know exactly what you need for this chassis for the right motor mounts. I only grabbed the adapters. I'll be using the factory 22re mounts. For now. If the burly v8 rips those, I'll upgrade. I'm trying to do the whole swap for under 2k.
Offline 2FastforChu
Re: 1UZFE SWAP
« Reply #27 on: Sep 20, 2016, 06:55:35 am »
o LOL I never knew that but they said i can just ship it back and they will do a exchange for it not to bummed out because cant work on car until i get back
1UZRA65
Re: 1UZFE SWAP
« Reply #28 on: Oct 14, 2016, 05:08:47 am »
Getting anywhere on this? My swap starts November 28th officially. I'll document it, pics and GoPro in hand, paying particular attention to the wiring aspect of documentation.
Offline 2FastforChu
Re: 1UZFE SWAP
« Reply #29 on: Dec 02, 2016, 05:01:04 am »
im bringing the car back from Los Angeles to San Francisco im now looking in to wheels because i cant find 14inch tires for the celica rims im debating between 17 or 15s
1UZRA65
