Author Topic: Another tire question  (Read 899 times)
Offline Mazinger
« on: Jun 17, 2017, 02:45:20 am »
I don't know if this one has been answered, I've searched. What cars came factory with the GT-S's tire size of 225/60 14? I came across a Subaru svx from the same era at the junkyard and it came with them. Are there others? thank you
85 GT-S white Hatchback Turbo
Re: Another tire question
« Reply #1 on: Jun 18, 2017, 03:34:49 pm »
Early Mustangs did as well, that's probably the only reason they're still made.
« Reply #2 on: Jun 19, 2017, 05:11:26 am »
That's one of those questions that really can't be answered, because so many models have different trim levels and options with various tire sizes.
« Reply #3 on: Jun 19, 2017, 10:56:45 pm »
Are you just looking for different wheels? Or looking for old junkyard tires? Either way man... there's a simpler way. You can almost run any 14" tire made for a passenger car on these cars. They have large wheel wells. I'm toying with the idea of 32" mud terrains... but also wheel wise you can use a tire calc to figure out what sizes would fit within the stock size.
Offline Mazinger
« Reply #4 on: Jul 03, 2017, 07:24:16 pm »
Yes, I was looking at junkyard tires as an option to the very few, and relatively expensive, new tires.  There may be other tires 14" that will mount, but I really rather keep it completely original.  I'll keep the search going.  So far, only a very early Mustang, and a mid 80s Subaru SVX are owners of this size.  So, the search goes on. Thank you all for the replies.
« Reply #5 on: Jul 04, 2017, 01:45:12 am »
if you don't mind going to a 215 you can get these for half the price of the Radial T/As
https://www.tirerack.com/tires/tires.jsp?tireMake=Riken&tireModel=Raptor+HR&partnum=16HR4RHR&vehicleSearch=false&fromCompare1=yes
Offline TerrenceLP
« Reply #6 on: Jul 12, 2017, 07:49:20 pm »
Just went through this - i decided to keep  the Stocker on the wall for now and I went with
225/60r15 on Bassett D-hole 15x7 with 4" backspacing or that comes out to 0 offset.
And all of that for the same price of 4 BF Goodrich T/A's @225/60r14
« Reply #7 on: Jul 12, 2017, 08:32:42 pm »
yea 15"s open up a lot more options.
Offline Dr.Jun.Manabe
  • Deez Bitches Rollin'
« Reply #8 on: Jul 12, 2017, 08:42:08 pm »
60 series 225 on a 15 is gonna be a bit bigger, 1/2 inch in height and your speedo will be off by about 4%.
'85 Celica GT Liftback -Black Lighter- (Daily)
-Megan AE86 32-way coilovers, T3 RCAs, T3 lateral bar, Cusco front tower bar, custom rear tower bar, boxed LCAs, ES poly bushings, Cube Speed short shifter, Stoptech slotted rotors, EBC Yellowstuff pads, Technafit stainless steel brake lines, Tomei 1.5 Way LSD, Rota Grid V wheels, Cusco Bride Vios 3 bucket seat, Nardi Classic 340mm steering wheel, stock motor w/ SV3 test pipe, 2.5in exhaust, and a cone filter.
'85 Celica GT Liftback -Evangeline-
'84 Celica GT-S Liftback -Silver Bullet- *SOLD* will be missed
'85 Celica Supra P-Type -Lucrezia- (2JZ-GE swapped, broken)
'73 Plymouth Scamp
« Reply #9 on: Jul 12, 2017, 09:13:20 pm »
Keep in mind the Basset rims are intended for racing. They're not designed to take hits from potholes and curbing, they're designed to be as light as possible.
« Reply #10 on: Jul 12, 2017, 10:18:26 pm »
If he bought the right ones Bassett makes a DOT approved wheel. It's what I plan on buying. If not the DOT version then those rims are designed for a race season of abuse and then thrown out, because danger to teh manifoldz.
« Reply #11 on: Jul 12, 2017, 10:19:17 pm »
The bassett wheels are probably still stronger than reps though. And since they are steel you can pound them back if it's not that bad.
« Reply #12 on: Jul 12, 2017, 10:32:50 pm »
You can also rebarrel those turds for unlimited wheel width. Eff yeah.
Offline TerrenceLP
« Reply #13 on: Jul 13, 2017, 12:21:41 pm »
Ha ha ha all good points!
4% speedo = I never look any way, years of Driving my Supra by RPM and Gear due to a broken speedo ;-)
I got the DOT version and the DOT is a regulated thickness, nothing more nothing less. They said the race lightweight D-hole wheels are plenty strong for street use, and they are $20 more and there was a wait. I no like wait!
At 15x7 you are talking @21.75 lbs vs @16 lbs for the lightweight's - I should'd waited :-(
Free Red Stripe !
Should be a nice aggressive race inspired look.
« Reply #14 on: Jul 13, 2017, 04:51:56 pm »
Don't worry about weights. Negligible unless setting world records. Also, most ppl don't realize it, but the tire you put on sometimes negates any weight savings over stock.
