Author Topic: Security system  (Read 1448 times)
Offline hadoken91
Security system
« on: Dec 28, 2017, 02:24:35 am »
I live around 10 minutes from the TJ border, lots of cars get stolen and taken there from my city. Any ideas on security besides a basic wheel lock? I sometimes take my ignition wires out lol.
Re: Security system
« Reply #1 on: Dec 28, 2017, 05:40:00 am »
What are you looking for? I mean, my ideas range from basic hidden kill switches, to rekeying to a more modern, less screwdriver friendly key, to a custom RPi/Arduino based push-to-start system with a breaker tripped if the original ignition cylinder is turned on. The level of difficulty is somewhat exponential.
Offline TerrenceLP
Re: Security system
« Reply #2 on: Dec 28, 2017, 07:46:20 pm »
Build a power Kill switch off of the mail Fusible Link and hide it somewhere in the cabin.
And build an ignition cut-off/relay -
So even if they figure out the power, there is no Ignition signal.
These cars have plenty of spots for False Switches, on one car my big Red KILL switch was actually the Start button - people are dumb! Most do what a sign says to do lol!~
Re: Security system
« Reply #3 on: Dec 28, 2017, 08:17:08 pm »
Hub’d aftermarket steering wheel. Take it in the house with you. Hidden Fuel pump kill switch. Battery disconnect switch. You can’t stop a thief, but you can slow them down long enough to make it not worth it
« Last Edit: Dec 29, 2017, 05:24:47 am by swan song »
Re: Security system
« Reply #4 on: Dec 28, 2017, 09:57:30 pm »
Heh, set up an arduino/PIC to recognize a tap pattern to turn on a secondary fuel pump relay.
Re: Security system
« Reply #5 on: Dec 29, 2017, 05:25:15 am »
That would be pretty dope.
Offline hadoken91
Re: Security system
« Reply #6 on: Dec 29, 2017, 05:43:23 am »
I think a kill switch would be sufficient. I am not that advanced in electronics so I will probably have to pay someone to to do it. Where would you suggest locating it?
Ty
Offline hadoken91
Re: Security system
« Reply #7 on: Dec 29, 2017, 05:44:05 am »
Thank you guys for all the ideas. I would implement all of them if I could lol.
Re: Security system
« Reply #8 on: Dec 29, 2017, 07:57:46 am »
Better: use the power mirror adjust buttons. Konami code ignition.
Re: Security system
« Reply #9 on: Dec 29, 2017, 05:26:26 pm »
Like what? Power mirror up/down, up/down, left/right, left/right, then honk the horn twice?  :heh: :heh: :heh:
You could probably hide a starter kill switch under the dash on the driver's left side and wire it up so you have to hold it down in order for the key to operate the starter.
Re: Security system
« Reply #10 on: Dec 30, 2017, 02:43:00 am »
Exactly! Except it's up up down down left right left right Brake Accelerator :P
The common wires to interrupt are, as mentioned, starter relay, fuel pump, or coil power. IMO, they're all too common, and fairly simple to bypass. Assuming it's an EFI car, I'd go for the signal from the crank/cam position sensor (in this case, the distributor pickup) to the ECU. Unless the thief finds the switch or wiring, the ECU isn't going to fire the injectors, so the car will not start. The best part is, that wire already passes through the dash on our cars, so assuming you've got an installer willing to find the loom, tear it apart, and reassemble it cleanly, it will not be easily found.
As for a hiding place, I'd suggest behind the ash tray, so the ash tray has to be popped out to flip the switch. Another option would be up underneath the dash, somewhere you can stick your fingers in to flip it, but can't actually see it from either the driver's or passenger's seat.
Offline DropTopZeek
  • Izaac K - Audio & Electronics Technician
Re: Security system
« Reply #11 on: Dec 30, 2017, 05:46:15 pm »
I have a detachable wheel and a viper alarm and I leave my car in some scary places but never had a problem. I just take the wheel and anything else out of the cabin.
1984 Celica GT-S Convertible
Daily driven, oversteer fiend.
-Raised from the dead zombertible
IG: @Berzeekeley
Re: Security system
« Reply #12 on: Dec 31, 2017, 06:24:12 am »
I think the best deterrent has been that our cars are so angular and old that they appear to be part of city structures or park art.
Re: Security system
« Reply #13 on: Dec 31, 2017, 04:10:03 pm »
Mine is a 5 speed, that's a pretty good deterrent around here. Nobody seems to know how to drive manual transmissions anymore. I was worried about my coupe (auto) so I put in an AutoPage alarm.
Offline hadoken91
Re: Security system
« Reply #14 on: Jan 01, 2018, 01:22:08 am »
lmao that may just be true
