So, here are my latest custom interior mods: S2000 engine start button and OEM pop-up button relocation!
I was originally going to put the start button in this panel where the passenger airbag switch would go (below the radio & HVAC controls), but then I had a better idea.
The location in which I had previously installed a toggle switch for my lights was a perfect candidate for the start button, since it's right next to the key. This required some precision filing to get the button to slide right through the panel. A bit of sticky string stuff (dum dum?) held it in place so it wouldn't slide in and out.
And then
this Revlimiter blog post explained the button wiring. I used a quality Delphi 30A SPDT relay so it'll last a good while.
So now, what about the pop-up switch? Well, now that I still had that passenger airbag switch panel available, I tried to take some inspiration from
another Revlimiter blog post to fit the OEM NA pop-up button in the panel.
I noticed that if you remove the plastic sticking out of the back of the airbag panel, and then remove the mounting tabs of the OEM hazard & pop-up button module and remove the hazard button...
...the button housing slides right in the back of the panel! The existing hole needed a bit of Hole Reaming
TM to properly fit the button through. A little bit of extra trimming allows space for the button backlight bulb to be removed and serviced.
This will look SWEET! I filled the unneeded holes in the panel with bondo, sanded it all down, primered, wet sanded, and painted the panel with Testors flat black enamel and Testors semi-gloss enamel clear coat for an OEM finish. I glued the button housing in with JB weld plastic bonder which worked really well.
And here it is installed!
