The Short Stroke Build:
So let’s get to the chopping part. But first, some measurement! With the MR2 shock and the OEM shock next to each other, you can get an idea of how much the strut tube needs to be shortened. Place the bottoms of the shocks against a flat block to get them sitting on the same reference plane, and measure the length difference from the tops of each shock.
I observed a height difference of 40mm, so that’s the amount to cut off the strut tube. But hang on a minute, how do those T3 gland nuts sit on the Koni shocks compared to the Koni gland nuts?
It seems the taper inside the T3 gland nut is too small, and doesn’t go all the way down to the lip that the Koni gland nut would sit on. I want it to fully capture the shock, so I took them to a shop to get them machined. The specs for machining are:
Mill the bottom right up to the threads
36mm ID counterbore, 6mm deep
Since the counterbore is pretty deep, I decided to only shorten the strut tubes 38mm (or 1.5”) to allow the shock to sit 2mm below the top of the strut tube.
Back to the strut tubes. Start by cutting off the stock spring perches, as you won’t need them anymore.
Cut out the section that the spring perch used to be in, since it’s easier to do that than grind the tube perfectly flat and then make a cut elsewhere. I used a horizontal band saw to make as straight cuts as possible. Carefully measure and mark the strut tube so you know where to line up the saw. First cut the line closest to the strut tube opening, then the one below it. Stay as far below the fine gland nut threads as you can!
Bevel the edges of the cut sections for improved weld penetration.
Here’s how it looks with a 38mm cut!
Now to test the gland nut – it looks like it captures the top of the shock and leaves a couple threads exposed. This is how the OEM gland nut looked with the OEM strut insert.
With the measurements verified, set up a welding jig that ensures the tubes are perfectly lined up with each other. An L-channel or U-channel works well for this.
Not the prettiest, but it’ll work!
Next, measure and mark where the new T3 weld-on spring perch ring will go. The T3 adjustable spring perch is 6” long, so the perch ring needs to be welded around 6 1/8” – 6 1/4” below the top of the strut tube. I used tape to make a ring that would hold the perch and adjuster in place, and lined it up such that the adjuster sits just below the top of the strut tube.
Ok, now the weld actually looks pretty.
I also had the brake line bracket welded on vertically to take some stress off the brake lines that were previously being pulled on from the steep angle of the OEM bracket placement. An air hammer and cutoff wheel took the entire bracket off the tube, then a bandsaw cut the unneeded part off, and it was rewelded at the same vertical height as before.
Once both strut tubes are ready to go, take the time to pretty them up. I sandblasted and painted mine in 500°F silver engine enamel. Don’t forget to blow out all the gunk that may have ended up inside the strut tube!
Before assembling the struts completely, you’ll need two more things – ultra high molecular weight (UHMW) polyethylene washers, and the installation of the pillow ball adapters from T3.
When you buy T3 RA64 camber plates, they supply a bag of adapters and shank nuts to allow various brands of shocks to center perfectly in the spherical bearing. The Koni shocks need the slimmer ones. Gently push them into the bottom of the spherical bearing. A little oil on the outer surface of the adapter may help.
The UHMW PE washers serve the purpose of decreasing friction between the Torrington bearing in the T3 upper spring hat and the gold block of the camber plate. When camber is dialed in, the bearing won’t sit flat against the gold block in the camber plate and it can create a lot of friction on the small contact point that it makes. It will also prevent metal-to-metal contact and decrease wear.
I got my sheet of UHMW PE from Amazon for $8. A 1/8” thick sheet is all we need. Both 1” and 1 3/4” hole saws are required to cut the washer. Start with the larger diameter cut, then clamp the washer in the vice and drill out the center!
With those sorted out, here’s the assembly order for the front struts, shown from left to right in the image below:
T3 O-rings, T3 adjuster sleeve, Koni shock, gland nut, QA1 bearing washer, QA1 Torrington bearing, QA1 bearing washer, Swift spring, T3 upper spring hat, UHMW PE washer, pillow ball adapter, camber plate, shock nut lock washer, shock nut.
Note that the T3 adjuster sleeve only goes in one way. The picture below shows the side that must face
down with a slightly larger ID opening; otherwise, you’ll have a hard time getting the o-rings to slip under the sleeve as you push it onto the strut tube.
The FSM also calls for 325ml of ATF to go into the shock tube before sliding in the strut insert, but I skipped this and just placed grease on the bottom of the shock for corrosion protection.
Snug down the gland nut down with the pipe wrench, and torque the shock top nut. Your strut assemblies are now complete!
