I'll have to take some more carryall pics, especially 4wheeling... but i keep forgetting the camera.
Anyhow, it has been drive-able for a month or so now, but is far from ever being done.
The old 235 engine will push it up to 60-70mph on pancake flat or downhill, but otherwise it cruises ~50, and 30mph on steep hills. Being what it is though, you don't mind going slow at all.
Unfortunately it leaks coolant into the oil (slowly), hopefully just the head gasket. But might be cracked block/head as the original radiator wouldn't hold water. Extrapolating knowledge of my Dad and family back in the 70s, it's safe to say they abused the piss out of that thing.
However, before I rip the head off (initiating a 2 month long case of while-im-in-here) it needs to do more adventures! Planning a road trip/camping trip in it next weekend!
Here are some pictures of the restoration activity:
First problem was that front left wheel hub was bubba welded to 4x4 axle spline coupling. So i cut that off
Then had to figure out how to get my wheel back, ended up using toyota truck wheel hubs and making some wheel bearing adapter sleeves
Toyota hubs are set up for disc brakes so I had to make some caliper mounts-
First a plywood prototype
and then some plasma cut brackets done by the guys at the steel yard
also added a power brake booster (mounted under the cab) and a brake fluid reservoir on the firewall, fashioned from a brake fluid bottle with a hose barb on the bottom, retained by a bean can. Perfect fit!
and some refurbished T100 calipers. This shot also highlights the original NAPCO, two piece closed knuckle design. Very nice for a non-power steering truck, since the knuckle turns on tapered roller bearings instead of ball joints. Less friction that way.
Though the knuckle bearings get hammered pretty bad over time, wearing unevenly since they only roll slightly back and forth for steering:
Then I needed to adapt the toyota (AISIN) locking hubs to engage with original NAPCO 4X4 drive axles. Fortunately the original spline coupler was still intact inside the bubba weld pictured earlier, and after some excavation with the grinder & lathe. I was able to weld old spline coupler inside the AISIN locking hub gear in order to create this adapter (pictured before welding):
Then rebuilt the differentials replacing the original 3.9 gears with 3.38 gears for modern speed limits
Then re-constructed the rear brake backing plate that had partially ground off when the wheel fell off sometime back in the day
Then cleaned 40 years worth of mouse poop / nests out of the doors. A couple trash bags worth + a trip to the carwash.
Wire brushed and painted the floor. Followed by carpet
Bought a new radiator, and made a new radiator mounting bracket
Re-packed the CV joints with grease. CV joints were a big deal back in 59, when most other 4x4s used U joints to drive the front wheels
Cleaned rust from underneath valve cover
stitched some new seat covers
Also re-built the gauge cluster, replaced wiring harness, & converted generator to alternator...
And am sooo done with this thing for a few more weeks until that engine starts bugging me again
