Ok after many a moon and working 70+ hours at work a week the past 3months. I have the great news of start up this evening!!! With that said I have a couple of questions, when. I jumped the connector to set the timing per manual set it to 5 degrees.. Turned engine off and unplugged jumper wire.. Started it back up and timing did not change at idle.. Should it? My idle is around 1k like hovering slighly up and below that. When I try to "goose" it she stumbles and pops and wants to die.. Checked for vaccum leaks none found. Did have to screw the idle adjustment screw all the in which i think I must have a vacuum leak somewhere but shouldn't the timing change with it unjumped or this might be vacuum leak causing it?
