I believe it's a way to prevent the car idling low when the alternator is loaded up. At normal idle it'll pull a few degrees of timing when manifold vacuum is high, but as RPM drops with load increase, it will see less manifold vacuum and increase timing to increase power a bit to maintain idle.
