Author Topic: 22r 2step/launch control  (Read 777 times)
Offline Joel87a
« on: May 13, 2019, 12:23:42 pm »
Just got it in and testing it out!
https://m.youtube.com/watch?v=gZoOr5aydZo
Re: 22r 2step/launch control
« Reply #1 on: May 13, 2019, 02:49:33 pm »
Awesome! What are you using for your low RPM cut-off trigger?
Offline Joel87a
« Reply #2 on: May 13, 2019, 04:19:34 pm »
Msd sells a stand alone 2 Step launch control module with adjustable limit that will cut sparkk,im using a msd 6al for the standard revlimiter
« Last Edit: May 13, 2019, 04:34:22 pm by Joel87a »
« Reply #3 on: May 13, 2019, 09:41:26 pm »
Nice. I meant, what triggers the launch control low-rev cutoff? The clutch pedal, handbrake, etc? Or does the MSD unit not use those...?
Offline Joel87a
« Reply #4 on: May 14, 2019, 02:37:03 am »
Oh gotcha sorry, you can wire it to any momentary switch the clutch pedal would be fine i have mine triggered by a momentary pushbutton switch on top of my shift knob that way i can preload the drivetrain by feathering the clutch a bit while still having it active
