Author Topic: Rear hub question  (Read 266 times)
Offline Jimep
Rear hub question
« on: Jun 08, 2019, 06:55:15 pm »
What is the purpose of the rear control arm rubber inspection/fill plug and drain plugs. Are the control arms supposed to be dry or filled with oil/grease for the rear hub bearings. Searched the interweb for a while but only finding broken links. Thanks!
Re: Rear hub question
« Reply #1 on: Jun 08, 2019, 10:30:15 pm »
I'm nearly certain they're only for noise reduction (think whistling over the hole at freeway speeds.)
« Reply #2 on: Jun 09, 2019, 07:53:25 pm »
They're to drain the control arms if they ever fill with water (and prevent water from splashing in).
The rear wheel bearings are packed with grease and then there are seals that keep them contaminant free, but they are not open to the control arms in any way.
Offline Jimep
« Reply #3 on: Jun 10, 2019, 04:18:25 pm »
Sounds like the answer I was looking for. Thanks!!! Both mine looked dry inside so leaving it like it is. Found the noise I was chasing was caused by a newer rear brake pad silencer plate, glue didn't hold and shifted.
