Author Topic: Local prices of Celicas?  (Read 1604 times)
Re: Local prices of Celicas?
« Reply #15 on: Sep 20, 2019, 08:30:51 pm »
Considering the cost of R&D and low volume manufacturing, $750 is not unreasonable. There's a company that makes a Honda K series to W5x bellhousing for $1500.
« Reply #16 on: Sep 20, 2019, 09:07:36 pm »
Agreed $750 for a low volume cast piece is nice. Also looks well made.
« Reply #17 on: Sep 20, 2019, 09:20:25 pm »
Yeah, Josh wanted the price to be extremely fair considering the R&D and tooling costs of producing a low volume piece like that.
« Reply #18 on: Sep 20, 2019, 09:42:26 pm »
plus the annoyance of casting something as large as a bell housing.
Offline patwhac
« Reply #19 on: Sep 20, 2019, 11:07:27 pm »
I guess nothing nice is cheap!!
1987 Toyota Corolla GTS Coupe (AE86) - Drift Car/Daily Driver:
https://www.youtube.com/watch?v=tkXSZUJG3A0
1970 Skylark - Buick 350 Twin Turbo Build:
http://v8buick.com/index.php?threads/patricks-twin-turbo-350-build-thread.344770/
*Rear Ended and Totaled*
1982 Celica GT-S - Daily/Occasional Track Car:
https://www.celica-gts.com/forums/index.php?topic=30921.0
Offline 83_Celica
« Reply #20 on: Sep 21, 2019, 12:12:04 am »
I love how this thread turned into something else  :laugh: I wanted to do the 2zz swap and was just gonna do a Lenco setu
https://lencoracing.com/index.php?route=information/information&information_id=17
Didn’t take smog or bar into consideration when thinking of the build  :laugh: I am tempted for the swap now that there’s bellhousings and transmission options :biggrin:
« Reply #21 on: Sep 21, 2019, 12:17:01 am »
dooo eeett :heh:
Offline 83_Celica
« Reply #22 on: Sep 21, 2019, 12:25:32 am »
dooo eeett :heh:
Fuuuund Meeee!!  :laugh: I will do it cause I want to join all these Honda guys. AWD superchargered 2zz 3rd gen anyone ? Or keep rwd?
Offline patwhac
« Reply #23 on: Sep 21, 2019, 12:36:23 am »
I've always thought Lencos look super badass. But the even the ST1200 is like $6000! In my Skylark I was actually planning to run a Killduff  lightning rods shifter, basically gives you the feel and operation of the Lenco at way less cost. Originally based on the factory option that came in the 80s Hurst/Olds Cutlass!  :spiteful:
https://www.kilduffmachine.com/
Don't remember if your build was with an auto for drag racing but you could probably adapt one of those shifters to your transmission of choice.
Offline patwhac
« Reply #24 on: Sep 21, 2019, 12:37:05 am »
I've always thought Lencos look super badass. And the modular design is freakin' sweet. But the even the ST1200 is like $6000! In my Skylark I was actually planning to run a Killduff  lightning rods shifter, basically gives you the feel and operation of the Lenco at way less cost. Originally based on the factory option that came in the 80s Hurst/Olds Cutlass!  :spiteful:
Offline 83_Celica
« Reply #25 on: Sep 21, 2019, 12:41:04 am »
I was gonna swap in a A340, I don’t want the W58 for long
Offline patwhac
« Reply #26 on: Sep 21, 2019, 12:48:03 am »
I see! I'm sure if your W58 works well you could sell it easily to make the swap cheaper (where are you located again? Because I could use a better one :heh:) You could always use an adapter and then run a TH400 if you're planning on making lots of power:
https://www.lceperformance.com/Transmission-Adapter-Plate-Kit-20R-22R-RE-To-Chevy-p/1033035.htm
I'm not sure how much power the A340 is rated for.
Offline 83_Celica
« Reply #27 on: Sep 21, 2019, 02:42:12 am »
A340 is rated at 400 hp (same as W58) but I wanted to build it and add  a trans brake and I am located in Souther California, specifically San Fernando Valley. Everything for this transmission works, I bought it from a local tranny dealer so it only has 1XX,XXX miles (he said it was a supra owned by an older lady) . Haven’t even driven it cause I bought the wrong pilot bearing for the 22RE :disgust: (found out after I pulled it) and the 7M still ain’t done. If you want it let me know cause I still have the 22RE bell housing and I still haven’t started putting it through hell :laugh:
« Reply #28 on: Sep 21, 2019, 02:53:06 am »
A quick google search turned up a few results saying nobody makes an A340 trans brake.
Offline 83_Celica
« Reply #29 on: Sep 21, 2019, 04:05:07 am »
I’ll make my own, I can figure something out. Won’t let that little thing stop me from trying, that’s what separates builds from owning a car. You gotta be a builder sometimes instead of a consumer especially in drag. Transbrake can be made to work I am sure of it. No one even lists a reason why it doesn’t work. Just say no one makes it and that’s it. I knew that from the start just need to talk to few transmission shops and a set up can be made (not cheaply but price of sticking to Toyota). W58 should hold for now
