Author Topic: Gremlin has struck.  (Read 1256 times)
Offline makah
Re: Gremlin has struck.
« Reply #15 on: Nov 27, 2019, 12:19:41 am »
Was thinking I might have corrupted firmware maybe running the msq file
22re 270eb cam, ss valves, ported, 93 probe afm, four hole 211cc injectors, obx header 2-1/4 exhaust- still the slowest car on the block until the first corner. Hondon't adjustable coilover w/proshock 250lbs front, trucoil 225lb rear, agx front to back, addco front, whiteline rear, energy suspension. some yellow brake pads for the front.  Everything else has been restored to better then oem. And new 3.90 gearset by MotiveGear.
Offline makah
« Reply #16 on: Jun 03, 2020, 05:53:41 am »
Though I would follow up ended up going to a 36-1 trigger wheel and coil on plug setup. Runs great now. No no power to ecu, fuel pump. Long time intermittent issue.
Offline makah
« Reply #17 on: Jun 03, 2020, 05:59:40 am »
thinking of just running a new separate circuit to the ecu. And power pump through megasquirt
