Wanted: 1985 Celica GTS gas tank new or used. If you know where I can buy a new one that would be great, but if you have a used one, it needs to not have any rust inside and of course it can't leak, so if there is rust on the outside it can't be bad, only surface so I can restore it. I'm in Dallas Tx and will travel to get it within reason. As you might not know, the gas tank on a GTS is not the same as the non GTS Celica. Thanks for your time.
