So a friend has an old Ford truck ('78 I think) and went to do a swap from the M series engine to a Windsor engine that's going to be on propane.
He bought an engine that had been recently rebuilt. It sat for quite a while and finally got around to installing it a little while ago.
The truck is up and running on propane but has a weird problem (note, I haven't seen the truck yet, as far as I know it's at the propane conversion shop.)
When cold, it cranks and starts fine. It will run until you shut it off. You can bomb around town, etc no problems.
However, when the truck is warm and you shut the engine off, it will not crank (as in: you can put a socket on the crank pulley and it refuses to budge.) If you leave it overnight it fires right up the next morning.
Can anyone think of anything that could cause this? I suspect whoever rebuilt the engine made a mistake somewhere. Given it's a conversion, I can't think of anything that can cause this. Starter shims? It's pretty obvious that something is expanding causing the problem.
I told him my best guess would be the bearing were not aligned with the oil supply holes. But even I'm not so sure about that.
