Author Topic: Bearings for GTS Rear?  (Read 1082 times)
Offline Jackson552
« on: Apr 29, 2020, 10:18:31 am »
I bought all the bearings and seals for my rear wheels as listed on rockauto but my mechanic said they weren't correct. Something about I needed pressed bearings and I had tapered ones or something... anyone have numbers for the IRS 1984 rear end bearings/seals?
คาสิโนออนไลน์
Re: Bearings for GTS Rear?
« Reply #1 on: Apr 30, 2020, 04:25:46 am »
I recommend a new mechanic if he is telling you that tapered bearings are wrong. The IRS uses tapered roller bearings.
« Reply #2 on: Apr 30, 2020, 02:13:03 pm »
I was kind of thinking that myself teran, the solid axle would have a press on bearing and press on collar to retain it while the irs should be tapered bearing. although I've never torn into the rear of a gts thats how most irs are. Maybe someone on the forum could do them probably save some money that way as well.
« Reply #3 on: Jul 07, 2020, 10:17:49 pm »
