Another update incoming!
Starting back again with the fuel system; I got a M14x1.5 to -6 AN adapter, hooked that up to a Fuelab 10 micron inline filter (81801-1), and now have my fuel feed setup ready! The fuel filter clamp fit on existing threaded holes in the engine bay, with a little filing action on the clamp holes.
I had my first go at making custom braided lines, which was very cool.
This little fitting converts the stock 1/4" fuel return tube to a -6 AN. I meant to get a 1/4" tube to -4 AN fitting from Vibrant, but it's been 2+ months, and it still hasn't arrived. This uses a standard 1/4" compression fitting for the seal, so it'll be very easy to replace when it comes time.
I then mounted up my 1995 4Runner charcoal canister behind the RH shock tower, again using existing threaded holes. Thanks Toyota!
One side needed a 1" spacer in order to utilize the stock charcoal canister mounting clamp.
And that all ended up being a very clean install.
Then it was time to address some heat shielding issues on the RH side of the trans tunnel where the fuel and brake lines run. Some DEI heat wrap took care of that. It has a fibreglass mat on the inside, and secures with velcro.
I put the rest of the remaining wrap on the steering shaft for good luck.
I was having issues with my Xcessive oil filter relocation block, as it was too thick and the sensor mounting location prevented the AC compressor from bolting on.
So I replaced it with this, the Blake Machine oil filter relocation block. It comes with -10 AN fittings and TWO sensor ports; one on the front, and one on the back.
I added a small 90 degree 1/8" NPT elbow from Vibrant to space the oil pressure sending unit away from the engine block, as there was a rib on the block that it would interfere with.
But, bam! The AC compressor fits up perfectly. Mr. Blake really wanted you to have AC with your UZ swap!
Next up was managing the mounts for the CXRacing S13 SR20 swap radiator. I started out with some "CAD" design to get an idea of what the mounts should look like. It was also important to make sure I could add rubber grommets to the mounts for vibration isolation.
Then I made the mounts by hand using 2" wide, 1/8" thick aluminum bar. The grommets came from McMaster Carr, since they had the odd sizes I needed.
I need more fabrication tools.
The mounts are super strong. I can bounce the car up/down on the radiator.
Clearance from the hood should be fine too, the radiator cap barely peeks out from the top of the radiator support.
Made these little spacers in order to keep everything secure.
I also dropped the fuel tank to replace the fuel pump for something a little more hefty.
Stock vs Deatschwerks DW200 (9-201-1000)
The body of the DW200 fuel pump is smaller than the stock unit, but it'll still fit just fine with the stock rubber grommet.
But, in order to keep the smaller FP body secure, I cut the original fuel pump hose and flattened it out to use as damper material, and added a hose clamp to further secure the FP.
Easily soldered up the connections with some heat shrink.
I tried to sort out the serpentine belt, but it won't be able to use the tensioner pulley properly. I'll have to look into some kind of solution to add an idler pulley where the PS pump used to be.
I also got a little treat for the W58!
Since I already have the BillyM shifter bushings installed, the shift lever pivot bushing had to be swapped over.
Going to see if patwhac can make me a little adapter bracket to add a Hurst shifter handle to the Cube shifter. ;-)
Finally, I got an ICT Billet battery tray for the Odyssey PC1200 battery.
Think I might mount the battery somewhere back here in the RH side of the trunk. I have an idea on how to mount the bracket on the sheet metal, securely, and keep the least amount of material poking through the metal since the fuel tank sits VERY closely to the sheet metal on that side.
That's it for now! Now that I'm working, I have even less time to work on the project, but I can't wait to get this thing running!
New YouTube episodes of the build are available as well, go give 'em a watch!
Episode 6Episode 7
