Welcome,
Guest
Login
or
Register
Home
Help
Search
Members
Login
Register
Celica-GTS.com Message Forums
General
General Discussion
2-tone wheel
Print
Pages: [
1
Author
Topic: 2-tone wheel (Read 373 times)
Panas332
Newbie
2-tone wheel
on:
Aug 01, 2020, 05:34:34 pm »
Sorry, I searched and can't find anything. I have one wheel off and I'm playing with how I want to refinish them. I want to paint the insides black, as well as the slots in the face. Then I'd like to polish the faces lightly.
I've seen this done lots of times, so what kind of paint and prep is needed? I thought about POR15 but I doubt that will stick.
tvดูบอลสด
Logged
twotone_ra64
Global Moderator
Forum Master
BACC Founder, Mechanical Design Engineer
Re: 2-tone wheel
Reply #1 on:
Aug 01, 2020, 08:17:31 pm »
I've refinished a couple pairs of wheels with a similar color scheme. Assuming you want to refinish the stock GT-S style wheels, it's gonna be tough to get inside the little nooks and crannies. I'd suggest getting them sand or vapor blasted.
Beyond that, I've used red scotch brite pads and 600 grit wet sanding to refinish wheels. Leaves the lip with a nice satin finish. Of course you can go further with finer grits of wet sanding and then compound. POR15 is really meant for chassis.
For these 15" Datsun Enkei meshies, I used the method described above with Rustoleum Automotive gloss black enamel paint. Took time to get inbetween the mesh slots by hand. 10/10 would not recommend, and would have taken them for vapor blasting.
For these 14" Enkei Easy Street replicas, I just threw on some of the same gloss black enamel, zero prep. Worked well though!
Logged
Celica the '84 Two-tone RA64
- Phase 2 In Progress! (159k);
1UZ-FE V8 Swap
W58 5-speed swap
Koni x Swift x T3 suspension
, 6G Celica seat belts, TRD 2-way LSD, Corolla tape deck
Mia the '91 Miata
- Revived Twice! (264k); BP-5A 1.8L swap, an NB in NA clothes
Lude the '95 Prelude Si
- The Tweaker Queen (237k)
Lilith the '94 Legend GS
- Blown HG (152k)
Print
Pages: [
1
General
General Discussion
2-tone wheel
