I finally got my car running well and driving fairly well, other then the lack of power and slight surging at anything over 2000-2500 rpms and on decel. When I was pulling the original engine I realised that the knock sensor wire was pulled out of the connector. Then noticed that someone soldered a repair wire to the inner part of the knock sensor wire, and neglected the sheilding. There is no connectivity between the inner, and outer wires so they didnt solder the 2 together.
From my understand the sheilding of the wire is supposed to be grounded, otherwise it will cause a check engine light, but I dont see any way in which the sheilding could make contact with ground through the connector considering where the shielding would be terminated. Is there something I'm missing, or just not looking at right?
I have a repair wire (PN 82998-12440), and a new connector (PN 90980-11166) from toyota.
